Brake Lights dont work - Ford Truck Enthusiasts Forums
Old 04-23-2011, 11:54 AM
Flawless_X Flawless_X is offline
Flawless_X is starting off with a positive reputation.
My Brake lights dont work but my third brake lights comes on and the tailights work too.
Old 04-23-2011, 12:31 PM
wallz's Avatar
wallz wallz is offline
wallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud of
Check fuses, then brake light switch on brake pedal. It helps with the de activating cruise.
Old 04-23-2011, 03:03 PM
saz2686's Avatar
saz2686 saz2686 is offline
saz2686 has a great reputation on FTE.saz2686 has a great reputation on FTE.saz2686 has a great reputation on FTE.saz2686 has a great reputation on FTE.saz2686 has a great reputation on FTE.
I had this happen on my explorer. It ended up being a wire pulled out of the switch activated by the brake pedal. I twisted the wire end up and shoved it in the slot it came out of and never had a problem thereafter. Good luck fixing it .
Tail Light Issues stuckstudent 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 10-12-2015 08:49 AM
Brake lights RDockery 1997-2006 Expedition & Navigator 1 09-16-2015 12:41 PM
brake and cargo lights dont work mike L 1987 - 1996 F150 & Larger F-Series Trucks 8 03-06-2015 01:07 PM
another trailer light thread.... AhoyMatey 1997 - 2003 F150 2 04-04-2014 05:35 PM
Brake light question Kurtboyd 1973 - 1979 F-100 & Larger F-Series Trucks 2 06-09-2013 09:08 PM
Tags
1967, brake, bronco, don, dont, escape, f250, ford, light, lights, sd, tail, v10, wont, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
