How removing the bed ?
Spray the bed bolts with PB Blaster and allow it to soak. (from the bottom) Have a torch and several big torx bits available, as you will likely break one (or more) (of the bits) Size varies a bit by year. Sometimes you can weld a nut to the bolt top.
There are a number of things attached to the bed, including the fuel fill. Again, depends a bit by year.
4 folks who have had their spinach can lift it off.
When you put it back together paint the bed bolts, or the grade 8 replacements, with anti-seize.
While the bed is off rinse off the frame and paint it with POR-15 or equivalent.
thanks for your help and replys
I sprayed in the screws with rust off and that was very helpful. One Torx bit is broken (home improvement store) and now I have to wait until Tuesday (Easter at the moment).
For your question "mikemass" No modification the border is a little bit twisted and so it is easier to remove the bed and then repair this.
But one question did I have @texastech_diesel what did you mean with IIRC ?
Thanks a lot
best regards
Thanks a lot
best regards
The bits are actually Torx-Plus, not regular Torx. Torx-Plus has thicker, stronger lobes, which is why regular Torx breaks in this application. The stock bolts are self tapping into the clips, so they usually gall and are near impossible to remove without cutting them from underneath.
gumshoe
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
01-22-2018 01:43 PM
