Does anyone have a pic of the vacuum lines hooked up to a stealth intake? I have a 1977 F150 with a 460, C6, AC and P/S. I know I need the line from the tranny. The distributor is an HEI unit, but I was going to pull vacuum from the Edelbrock for that. I guess I would just like to see where on the intake to put the vacuum tree with the temperature sensor in it. If I am way off base, please let me know.
The vacuum for the trans should be hooked up to the port on the #4 intake runner. The temp sensor should be hooked up to the threaded port IN FRONT of #5 intake runner, not the one on the runner itself, thats another vacuum port.
I sure do appreciate it. That is exactly what I needed to know. Thanks again.
So is it better to hook up the tranny to the runner on 4 versus the back of the block? Mine is the on the back of the block, maybe that why tranny shifting not right.
