O2 sensor and new exhaust system - Ford Truck Enthusiasts Forums
Old 04-22-2011, 05:36 PM
SoCar72 SoCar72 is offline
SoCar72 is starting off with a positive reputation.
92 F-150, 4x4, 5.0 EFI, 5-sp
I have a set of shorty headers on my truck. Each header has an O2 bung in the collector. Currently, my stock exhaust system has the O2 sensor mounted in a short balance tube between the 2 bank pipes just before they enter the first catalytic converter. I'm looking to install a new exhaust system. Where to put the O2 sensor?
The header bung(s) are really convenient. Would placing the sensor in one header collector cause any issues for proper metering of oxygen content being that it would only be sensing that one bank? Would the close proximity to the exhaust ports be too hot for the stock sensor?
Or, should I place a sensor in each bank and wire the 2 sensors in parallel? I suspect wiring them in series would cause false readings. But, would 2 sensors create a funky reading? I suppose these sensors register their findings by resistance variations in the 12v power in a similar manner as electric temp and pressure sensors do. I also suppose that both would be read as whichever offers the strongest signal.
Or, should I stick with the "stock" method and install a bung centered in the balance tube?
Thanks!
Old 04-22-2011, 05:54 PM
timbersteel's Avatar
timbersteel timbersteel is online now
timbersteel has a good reputation on FTE.timbersteel has a good reputation on FTE.
The new headers you have wih the bung in the collectors are more for the Sequential EFI system which each cylinder get's it's own injector pulse width from the EEC. Since our system of Speed Density for the trucks is batch fired, there is only "1" bung and that is the right @ the "Y". That's the best location for your setup. If you did the Speed Density to MAF setup, then having the O2 bung in the colector is a (+). You will need 1 O2 sensor in each bank so the EEC can monitor if either side is running Rich or Lean.
I have thought about the notion of wiring in "2" HEGO sensors, since all I would need to do is get a driver side exhaust manifold with the O2 sensor bung and use the passenger side one together. For some reason, the passenger side exhaust manifold had an O2 sensor bung. I think someone got it by mistake.
Edit: If I'm wrong, someone correct me. This was my understanding after much research, but I could have been mislead in my reading of the O2 sensor and the placement in the collectors and "Y" pipe.
Old 04-22-2011, 06:29 PM
cjben cjben is offline
cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.
You only need one oxygen sensor,I put mine in the passenger's side collector,engine has ran fine for 2 years just reading one bank.(well,it was running fine,now needs a timing chain so it will run again,waiting for it to stop raining for more than a day so I can fix it.)
Old 04-22-2011, 10:02 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Use the bung in the passenger side header it will work fine there, I have been running longtubes like this for 15 years and the truck even passes sniffer tests.
Old 04-23-2011, 05:03 AM
lew52's Avatar
lew52 lew52 is offline
lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.
Yeap , passenger side header , even with MA sequential EFI you only need one , the mustangs had two but the trucks only have one.....
Old 04-27-2011, 10:57 PM
I really like the passenger side bung idea. I'll do that. Thanks for the input.
Exhaust; bungs or no bungs? tuffnufly81 6.4L Power Stroke Diesel 1 01-07-2013 06:05 PM
headers and o2 sensor ItsAFord55 1987 - 1996 F150 & Larger F-Series Trucks 5 07-04-2011 09:06 AM
o2 sensor and headers loseboltssinkships 1987 - 1996 F150 & Larger F-Series Trucks 14 02-12-2011 06:44 PM
302 MAF conversion, headers? Dannym Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 02-16-2006 07:30 PM
Dual Exhaust on 96 F150 5.0 2x4 automatic Ron Exhaust Systems 2 06-10-2000 01:00 PM
Tags
1996, 62l, 95, 96, bung, collector, f150, ford, header, o2, oxygen, sale, sensor, sensors, stock, wideband
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
