1997 F250 transmission problems
Old 04-22-2011, 12:18 AM
neader's Avatar
neader
neader is offline
Hi everyone just got 97 F250 diesel but the speed <!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]-->odometer doesn’t work and the
transmission take a long time to go to second gear than it kicks hard and the other gears go down and up all crazy could someone help with any suggestions.
Old 04-22-2011, 07:25 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,575 Likes on 1,053 Posts
Fix the speedometer and then the trans will be fine. Most likely it's the speed sensor on top of the differential on the rear axle.
Old 04-22-2011, 11:46 PM
neader's Avatar
neader
neader is offline
Thank you will do that and I hope that will do the trick. I will let you know
how it went.Thank you for your help Once again.
Old 04-23-2011, 11:16 PM
neader's Avatar
neader
neader is offline
Mark you hit it right on it was the speed sensor now it's working just fine.
Thank you for your help.
Old 01-09-2013, 01:00 AM
Brendaboop's Avatar
Brendaboop
Brendaboop is offline
I have questions and don't see where to post. . . only post a reply HELP!!!!
Old 01-09-2013, 10:02 AM
Mark Kovalsky
Go up one level to the Clutch and Transmission forum page. Near the top on the left side is a button that says "New Thread.". Click there.
Crazytown
10-09-2012 11:13 AM
porthole
6.7L Power Stroke Diesel
41
08-22-2012 03:47 PM
JPs2003
28
03-05-2012 10:15 AM
Rhino99
Modular V10 (6.8l)
32
01-18-2011 04:04 PM
mvedepo
10-05-2010 11:42 PM
Quick Reply: 1997 F250 transmission problems
