1997 F250 transmission problems - Ford Truck Enthusiasts Forums
Old 04-22-2011, 01:18 AM
neader neader is offline
neader is starting off with a positive reputation.
Hi everyone just got 97 F250 diesel but the speed <!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]-->odometer doesn’t work and the
transmission take a long time to go to second gear than it kicks hard and the other gears go down and up all crazy could someone help with any suggestions.
Old 04-22-2011, 08:25 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
Fix the speedometer and then the trans will be fine. Most likely it's the speed sensor on top of the differential on the rear axle.
Old 04-23-2011, 12:46 AM
Thank you will do that and I hope that will do the trick. I will let you know
how it went.Thank you for your help Once again.
Old 04-24-2011, 12:16 AM
Mark you hit it right on it was the speed sensor now it's working just fine.
Thank you for your help.
Old 01-09-2013, 02:00 AM
Brendaboop Brendaboop is offline
Brendaboop is starting off with a positive reputation.
I have questions and don't see where to post. . . only post a reply HELP!!!!
Old 01-09-2013, 11:02 AM
Go up one level to the Clutch and Transmission forum page. Near the top on the left side is a button that says "New Thread.". Click there.
'99 F150 Replacing Ignition Actuator BDB513 1987 - 1996 F150 & Larger F-Series Trucks 1 07-21-2014 05:38 PM
LED Swap Out - Headlight Switch (Pix Working now) JPs2003 1999 - 2003 7.3L Power Stroke Diesel 28 03-05-2012 11:15 AM
Certificate Label Question for 1980 Ford F100 RTennant71 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 09-19-2011 04:35 PM
No Power 84 Bronco 351 W hanke777 1978 - 1996 Big Bronco 24 03-01-2011 04:07 AM
Ziebart....Worth it? mvedepo 6.7L Power Stroke Diesel 9 10-06-2010 12:42 AM
Tags
1997, 97, diesel, f250, ford, gear, kicks, problem, problems, slipping, stays, tranny, trans, transmission, wild
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
