dirty dages bottle
Old 06-03-2014, 10:46 AM
schonauer's Avatar
schonauer
schonauer is offline
dirty dages bottle
I have a black line around the top of my degas bottle,what could this be from.
Old 06-03-2014, 11:23 AM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
MOOSE_MACHINE is offline
Does it have a oily look to the top of your coolant or smell like fuel a bit
Old 06-03-2014, 11:57 AM
schonauer's Avatar
schonauer
Coolant looks clean no oil or smell, truck is a 2000 with 118,000 miles on it.
Old 06-03-2014, 04:25 PM
djed's Avatar
djed
djed is offline
I had the same thing on my truck.
First I had my oil tested at Blackstone - thankfully with negative results. Potassium or sodium levels in the oil would indicate coolant in the oil.
Second, since I am new to the truck, I didn't know if the "soot" was residual from a prior event or symptoms of a new problem. I drained enough coolant (into a clean bucket to put back in) and removed the coolant bottle which I cleaned with soapy water. I could only get a rag into the first chamber so the other three chambers had soot which I couldn't remove. My goal in doing this is to see if the soot returns (which thankfully it has not).
Third, I put on a Dieselsite coolant filter.
Finally, I checked the oil dipstick for irregularities (which I did not see).
I'll try to post pictures later on.
As an aside, my oil cooler orings were recently replaced. I'm sure others will chime in and suggest that oil - coolant crossover often occurs as a result of deteriorated orings in the oil cooler.
Good luck.
Old 06-03-2014, 05:40 PM
Tugly's Avatar
Tugly
Tugly is offline
Hmmm.... Did it look like this?
Old 06-03-2014, 07:46 PM
schonauer's Avatar
schonauer
Yes it looks just like that Tugly.
Old 06-03-2014, 11:40 PM
djed's Avatar
djed
djed is offline
Pictures of my degas bottle before cleaning:
Except for clear condensation, my degas bottle is clean at this time.
Although I forgot to mention it above, I did pressurize my coolant system to 15psi and I didn't see a pressure drop over the 15 +/- minutes that I kept the pressure on. In case it helps, A/Ox4 puts out a YouTube video on how to pressure test the cooling system.
Unless the soot returns, I'm going to assume the soot was from a residual problem. If I were you, I would do the same.
I think the other thing I read about when researching the issue was the potential for cracked injector cups. I believe you can test that by removing the injectors and pressurizing the coolant system. Unless the soot returns, I don't think it's necessary to go there.
Old 06-04-2014, 05:16 AM
Tugly's Avatar
Tugly
Tugly is offline
Well.... If it's that... the problem is not easy, or it's really terrible:
In my case, it took two problems in conjunction to get soot into the degas bottle.
1. Leaking copper washer on the injector nozzle or a loose injector.
2. Cracked cup below the injector fuel O-ring.
The "epic" saga is in the injector cup link in my signature.
The really-terrible: It could be a blown head gasket, but these are extremely rare.
Are you getting loud injector knock, bucking and jerking at just the right throttle, and really smoky startup?
Old 06-04-2014, 12:41 PM
schonauer's Avatar
schonauer
No smoke on start up no knock truck runs good,I think I'll clean the ring off the degas bottle and put a new coolant filter on an see what happens.
dbdbb
10-07-2014 04:49 PM
F-250BOB
03-10-2014 01:38 PM
Luggy
01-07-2014 09:50 PM
broncxl302
15
09-14-2009 09:57 PM
Flobber
08-07-2008 12:19 AM
Quick Reply: dirty dages bottle
