What Just Happened? Blew A Fuse..But Why? - Page 2 - Ford Truck Enthusiasts Forums
Old 04-23-2011, 04:56 PM
big poppa's Avatar
big poppa big poppa is offline
big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.
Nice writeup Ken.... My truck did the exact same thing. Glad you figured it out and was back on the road, I had my codereader but my kids took my fuse testers out of my truck so was forced to tow my truck home, not entirely their fault but didn't help matters, I might have figured it out. This site helped me figure out what was going on with much thanks..
Old 08-03-2011, 01:45 PM
dobbinite dobbinite is offline
dobbinite is starting off with a positive reputation.
Lost control of throttle & instrument panel dead
I experienced the same problem described above this morning. My 2002 F350 7.3D was ready to go to work this morning but died in my driveway. Chilton book was no help. Luckly I still had the owner manual to designate the fuses. I could not see any blown fuses obviously. Finally searched the net and found this site and this thread. I went back with an ohmmeter and systematically checked each fuse. #45 (ig sw feed) was blown but hard to see. Replaced the 10A and got're going again. Thanks a million, guys. High Fives for the internet and this blog.
Mick
Old 08-08-2011, 12:45 PM
I am reading a lot of posts about this shorted O/D cable problem. I repaired mine with tape a few days ago, but last night it failed one more time again. My question is : if I disconnect the O/D switch for a while to isolate the problem some more, will that just allow the O/D to remain on or will it affect the PCM control of the transmission?
What if you are driving down the interstate with a 2000lb load and this happens ? You lose throttle control, what's going to happen next ? It seems to me this should be a Ford recall issue. Any comments ?
Old 08-08-2011, 12:56 PM
Shake-N-Bake's Avatar
Shake-N-Bake Shake-N-Bake is offline
Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.
Since the engine stays running when that fuse blows, you should still be able to safely stop on the side of the road....but I agree, should be a recall item in my opinion as well.
You might want to split open the sleeve and inspect the insulation on the individual wires. Chances are that you have bare wires in that sleeve and they are touching each other.
I don't now what will happen if you leave that disconnected. If you decide to try running it that way let us know what happens.
Old 08-17-2011, 05:25 PM
cable in shift lever
I unplugged the O/D switch from the steering column connector. The truck runs just as before, except of course you cannot turn off O/D.
I never used that switch much anyway, at least the fuse blowing problem has left. Since repairing the cable did not work, I will just leave it disconnected. A permanent fix will be replacing the shift lever and cable assembly someday.
Old 08-17-2011, 05:38 PM
Should work fine. I replaced the shifter on my white truck last December. The cost was $41.99 from PartsGuyEd. Seemed reasonable for an OEM part.
Old 08-17-2011, 06:00 PM
shifter
I looked at PartsGuyEd site, but I can't find this parts under any of their categories. If you have their P/N I will order it.
Thanks, Mick
Old 08-17-2011, 06:39 PM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
Thanks, Mick
Steering column > Housing and components > Gear shift lever
Edit: Tip - If you can get close click View Illustration and you may find the part.
Old 08-17-2011, 06:51 PM
In Robin's picture above...
  1. Item #1 is the assembly 5C3Z7210AAA (this comes with the button and retainer)
  2. Item #2 is the switch (button) F58Z7G550AA
  3. Item #3 is the retainer for the button F2UZ7A214CA
Hope this helps.
Old 08-17-2011, 07:00 PM
PaysonPSD's Avatar
Hope this helps.
Item #1 comes with #2 & #3, but #2 & #3 can be ordered separately.
Right?
Which items come with egg roll?
Old 08-17-2011, 07:04 PM
Quote:
Right?...
Correct.
Ed didn't send me a link for the egg rolls....I think he needs your VIN # for that.
I presume you'll be coming for Chicken Quesadillas on Labor Day weekend....no part number required. Just keep me away from your Kool-Aid.
Old 11-18-2012, 03:33 PM
bigshoe bigshoe is offline
bigshoe is starting off with a positive reputation.
oops! wrong fuse
OK, same problem with overdrive button. i put some tape around it and made it for awhile but had used all my 10 amp fuses. i put a 30 in it just to get back to camp where i had tools and fuses in my 97 f250 turbo diesel. didn't make it. i had a new shifter brought out to me and put it in with new wires but it didn't blow the fuse and now i have same problem with no blown fuse? just wanting to know if i should start at that wire or at the fuse panel??
  #28
Old 11-18-2012, 05:32 PM
reply
I just disconnected the overdrive switch. Its always in OD in high gear but thats OK works for me. If that does not work, you need to trace the 12v line to the IG sw and run a replacement wire.
Hope you didn't fry the wires in bundle.
Auto Electric shops are good at fixing this kind of problem.
  #29
Old 11-18-2012, 07:14 PM
I just tried unplugging it and no chamge.you think the wire down from there or start at the fuse box?
  #30
Old 11-18-2012, 07:17 PM
Thank you,i tried unplugging it, no change.i am blessed enough to have a couple other trucks so not in desperate need.just trying to figure it out.do you think start with the wire and work down or the back of the fuse box?
2000 Ford Expedition xlt battery saver relay clicking no start websurfer 1997-2006 Expedition & Navigator 13 11-14-2016 03:22 PM
AOD experts please help...rebuilt tranny Flintknapper Clutch, Transmission, Differential, Axle & Transfer Case 17 02-18-2015 09:00 PM
1966 f100 door tag decode request plum bob 1961 - 1966 F-100 & Larger F-Series Trucks 1 02-10-2015 08:17 PM
Random Powerstroke stalling/misfire torquemitefs 1999 - 2003 7.3L Power Stroke Diesel 6 06-21-2013 03:51 PM
BURN IT TO THE GROUND cbr600rx7 1994.5 - 1997 7.3L Power Stroke Diesel 47 01-30-2013 06:48 PM
Tags
2003, 650, 73, 99, accelerator, aux, blew, f350, ford, fuse, gauges, mirrors, port, power, powerstroke, put, runs, towing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
