84 460 vac hose routing.. - Ford Truck Enthusiasts Forums
Old 04-21-2011, 11:42 PM
axman_F250's Avatar
axman_F250 axman_F250 is offline
axman_F250 is gaining momentum as a positive member of FTE.
Well, I feel pretty dumb asking, but desperate times call for desperate measures. 84' 460, Holly 4180. Needing help with vacuum hose routing - almost all of it.
I have no vacuum hose diagram on the radiator support. Diagrams available on Autozone do not help, they don't match - badly. It might also be that I'm just not swift enough to transpose what I see in the diagrams to what's on my truck. Anyway, I found a good post here on vac system acronyms, and I learned a good bit from this;
http://www.ford-trucks.com/forums/97...ved-and-2.html
But what would really help is pics of what goes where from a properly connected system, anything between 1982-86? Or a pic of someone's vac hose routing diagram on the radiator support from a mid-80's 460?
But maybe that is too much to ask. I've taken pics of the mess I inherited, will post them if anyone feels like holding hands for a while I ask dumb questions. Please feel free to heap scorn upon me for not figuring this out..
Old 04-21-2011, 11:52 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
To make your situation worse, those diagrams are dependent on the Calibration Codes from the factory; they're not all the same.
Old 04-22-2011, 09:24 AM
85lebaront2's Avatar
85lebaront2 85lebaront2 is offline
Old School Hot Rodder
85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold
I can scan my replacement diagram from my 86, but it will be Sunday evening after I get home. It is an over 8500 GVWR system with the dual air pumps and non-catalyst. It may not match yours at all though.
Old 04-22-2011, 10:39 AM
axman_F250's Avatar
Quote:
Crap.. Well, hopefully looking at someone else's would at least get me in the ballpark. Right now, I'm faced with trial & error - lots of error. But good to know, thanks.
Quote:
Thank you, kind sir! Very much appreciated, and understood that it won't be an exact match. But it would be better than guesswork at this point.
Old 04-22-2011, 11:04 AM
Sw1tchfoot Sw1tchfoot is offline
Sw1tchfoot is gaining momentum as a positive member of FTE.Sw1tchfoot is gaining momentum as a positive member of FTE.
Is everything there or did someone gut most of the emmissions?
Old 04-22-2011, 11:42 AM
axman_F250's Avatar
Quote:
Half & half.. Was missing smog pump, AIR bpv, and all the plumbing. Got replacements at j/y. The VCV's are there, I think the correct quantity.. EGR is there. But all the vac hoses are either plugged or connect to nothing.
Old 04-23-2011, 11:34 AM
axman_F250's Avatar
Hey Sw1tchfoot,
In this post, http://www.ford-trucks.com/forums/10...-the-carb.html
you mentioned
The small one that is pointed out at an angle out of the main body is for the EGR, if you do not have this one and you instead have one coming out of the metering block (bolted between the bowl and the main body); then this it is not a 4180 and you can disregard what I mentioned.
Do you mean this one?
If so, I have one less vac hose to struggle with.
Old 04-23-2011, 03:12 PM
Quote:
Originally Posted by axman_F250 View Post
Hey Sw1tchfoot,
you mentioned
The picture did not load for me, so heres another picture to show which one I was talking about:
The port at the very top of the picture.
Ford does a lot little stuff, so I do not believe that the EGR connects directly to this port, it probably goes to a switch of some sort just like the vacuum advance goes to a coolant switch so it can switch between manifold vacuum and ported vacuum at a certain temp. But it would probably work connected directly to that port if that is the case. Just like most people disregard the coolant switch for the vacuum advance and just connect it directly to the carb.
Your 4180 might not have the choke pulloff that is in the picture, my old 4180 didn't.
Edit: The picture is working for me now, yes that is the one.
Old 04-23-2011, 10:04 PM
axman_F250's Avatar
Thanks for confirming!! One less hose to worry about. Thanks again!
Old 04-24-2011, 12:45 PM
Coneynew's Avatar
Coneynew Coneynew is offline
Coneynew is starting off with a positive reputation.
Here is the Vacuum Decal on my 85 F-350w/ 460 Non-Catalyst
Old 04-24-2011, 06:17 PM
axman_F250's Avatar
Coneynew, THANKS!! Looks a lot closer to what I actually have. Much appreciated!
Old 04-24-2011, 08:32 PM
Axman, when I got home I looked in my AllData and found the 1984 Diagrams. 3-97J-R10 is manual trans. and 4-98S-R0 is automatic trans. Unfortunately the Adobe pdf printer turns it into a negative, but here they both are.
Old 04-24-2011, 10:06 PM
Coneynew's Avatar
Glad to help out. For the most part the color codes match the vac lines on my truck. What is crazy is that the diagram looks simple, but when I remove the air cleaner, wow, looks like spaghetti and 10x the lines...
Old 04-25-2011, 10:26 AM
axman_F250's Avatar
Hey Bill - THANKS!! With these diagrams and the pic from Coneynew, I'm confident I can get the hose routing all squared away. Very much appreciated!! Hope I can return the favor someday..
Old 04-25-2011, 02:01 PM
Hey, no problem, that's what this group is all about.
Is this the best these brakes will get? Papawheelie 1987 - 1996 F150 & Larger F-Series Trucks 30 02-23-2017 06:14 AM
Ford Dump Truck 1942-47 - What year Biggoomba 1947 and Older Ford Trucks 41 11-27-2013 08:07 PM
Mods, Maintenance, and Life(long and kind of pic heavy) redman84 1994.5 - 1997 7.3L Power Stroke Diesel 17 05-29-2013 01:38 PM
Air Zenith OB2 compressor :-( porthole 6.7L Power Stroke Diesel 10 05-16-2012 07:34 PM
Camshaft???? RANGER589 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 18 06-03-2011 11:03 AM
Tags
1982, 400, 460, 82, 84, 94, ac, diagram, engine, f150, ford, hose, hoses, line, pics, routing, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
