Keyless - Ford Truck Enthusiasts Forums
Keyless
Old 04-21-2011, 09:12 PM
ramrunnr's Avatar
ramrunnr ramrunnr is offline
ramrunnr is starting off with a positive reputation.
Keyless
I just got a 1991 F-350 SuperCab Dually and the previous owner (her late husband was the second, I'm the third owner) doesn't know if the truck had keyless entry, but I think that it might, as it is a XLT Lariat.
Is there anyplace that I can look on the truck to find out if it does have it? I've tried VIN searches, but have come up empty.
I have also googled around the web and have come up empty.
Old 04-21-2011, 09:38 PM
SideWinder4.9l's Avatar
SideWinder4.9l SideWinder4.9l is offline
SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.
I may be wrong, but keyless entry wasn't a factory thing.....Dealer/owner add on...
Old 04-21-2011, 11:47 PM
ramrunnr's Avatar
Quote:
I found the Part number for the add on module for a truck with out it, but where would the module be mounted on the truck once installed? If the unit was installed previously all I need to do is get replacement remotes.
Old 04-22-2011, 01:29 AM
hammerhead90's Avatar
hammerhead90 hammerhead90 is offline
hammerhead90 is gaining momentum as a positive member of FTE.hammerhead90 is gaining momentum as a positive member of FTE.
Dunno about the 91's, but the 92-97 trucs had the module behind the kick panel on the driver's side
Old 04-22-2011, 02:06 AM
TexasGuy001 TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
I didn't think keyless entry was a factory option until the 92-96 trucks.
Keypad keyless entry on F350 F350 king ranch 1999 to 2016 Super Duty 5 09-01-2013 05:06 PM
remote start with key-less entry question fordguy2236 1997 - 2003 F150 2 07-13-2013 10:49 PM
1996 F-350 Keyless Entry Lt. Destructo 1987 - 1996 F150 & Larger F-Series Trucks 5 10-17-2009 03:48 PM
Keyless entry? herothc2003 1997 - 2003 F150 3 12-26-2006 09:29 AM
programing keyless pad on 03 Sport Trac boilerperson Explorer, Sport Trac, Mountaineer & Aviator 1 04-06-2006 11:42 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
