Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 04-21-2011, 07:35 PM
church4629 church4629 is offline
2000 Mazda MPV
My Garage
church4629 is starting off with a positive reputation.
high pressure oil line blew...2000 F250 7.3 liter
222K miles and I need Help...driving home last night and I heard a pop type sound started researching around today and thought I lost a fuel line but after the wife came out and cranked it for me noticed the fluid coming out the Oil pressure line from the Oil pump to the head on the left bank..SO...I read a bunch of post on here to remove them, some said with a pair of screwdrivers and even got a window regulator remover that is almost the same size...been under the rubber piece and pulled up and pushed down on the braided hose and still nothing...and this is the easiest one to get at under the air intake....been on top of the rubber piece and pushed it down and still nothing is there a trick to get these off...this is my daily driver and I need to get these off and get some two new ones in the morning...wife is missing her vehicle..
  #2 (permalink)
Old 04-21-2011, 07:49 PM
2000 Mazda MPV
My Garage
found a picture...maybe I'm not pushing hard enough./..
As far as pics what are you looking for?
TSI Number: 07-12-09
TSI Date: June 2007
Subject File: Engine
SUBJECT
New High-Pressure Hose Assemblies
APPLIES TO
Engine Family: T 444E
DESCRIPTION
New high-pressure hose assemblies are available. The wire braid of each new hose assembly has a silicon molded sheath to protect the hose from corrosive elements.
New part number hoses will be substituted for orders of old part number hoses.
Description
New Part No .
Old Part No .
High-pressure Hose Assembly
1880058C1
1824431C1
1880069C1
1830931C1
High-pressure Hose Assembly - left
1880070C1
1831420C91
High-pressure Hose Assembly - right
1880061C1
1827889C91
1880024C1
1831422C91
1880025C1
1831685C91
Service Interval
Install new high-pressure hose assemblies every 161,000 km (100,000 miles).
Removal and Installation of High-pressure Oil Hose from Cylinder Heads to High-pressure Oil Pump
WARNING:
To prevent personal injury or death, dispose of oil or discard components, according to applicable regulations.
WARNING:
To prevent personal injury or death, do not let engine fluids stay on your skin. Clean skin and nails using hand cleaner and wash with soap and water. Wash or discard clothing and rags contaminated with engine fluids.
High-pressure Oil Hose (Threaded Couplings)
See Engine Service Manualfor removal and installation procedures.
High-pressure Oil Hose (Quick Disconnect)
Disconnection of high-pressure oil hose
1. High-pressure oil hose
2. Steel flange
3. Quick disconnect tool
4. Rubber umbrella
5. High-pressure oil pump
1. Insert fork of the quick disconnect tool ZTSE4449 between the rubber umbrella and the steel flange on the high-pressure hose.
NOTE: Prying or leverage with the tool is not necessary and will only result in tool damage.
2. Pull lightly on the hose to remove it from the fitting.
3. Install high-pressure hoses. Make sure that you hear a click, when inserting hose end (steel flange) into quick disconnect connector.
CAUTION:
To prevent engine damage, make sure high-pressure hose connections are secure.
4. Pull on hose connections to verify secure engagement.
Š 2007 International Truck and Engine Corporation
  #3 (permalink)
Old 04-21-2011, 07:52 PM
2000 Mazda MPV
My Garage
pic's didn't come across
  #4 (permalink)
Old 04-21-2011, 10:09 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
Garage is empty, add now
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Moved to the 1999 - 2003 7.3L Power Stroke Diesel forum.
__________________
John
2011 F-350 4x4 Lariat Ultimate, Oxford White / Pale Adobe 6.7L PSD 3.55 ELD / Gone but not forgotten.
2013 Ford Taurus SHO, Tuxedo Black / Black Leather
Moderators, Guidelines, and How They are Enforced / FTE Forum Guidelines
Currently truckless
  #5 (permalink)
Old 04-21-2011, 10:44 PM
woodnthings's Avatar
woodnthings woodnthings is offline
2002 Ford F-350
woodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud of
Take look at this see if it helps.
YouTube - Eaton STC Fitting removal
__________________
Ken
2002 F-350 CCLB 4X4 Website, HD4R100 , T-500, Melling LPOP, Gen-2 FRx, Bellowed Up-Pipes, Riffraff OCR, , Braided Brake Lines, CAC Boots & Billet Plenums, Aeroforce Scangauge, 4" Diamond Eye, Powerslots, Ported Compressor Housing, DP Tuner-F6, AE, KCM S.S. HPX, S&B Filters intake, Quad pod w/ISSPRO EV2's, Big Head , 6.0L Trans Cooler,
  #6 (permalink)
Old 04-21-2011, 11:15 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32 weekendwarriorfsw32 is offline
Master of Strokes
2004 Ford Excursion
My Garage
weekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud of
Great video.
__________________
Nick PAA#9
08 F-450 KR 6.4 Elite Race Trans, Elite 71mm turbo, ARP, RDP I/C Boots, 5.5 Icon lift, 22.5 AF Independence wheels, OUO
04 X 6.0 Powermax, ARP studs, MBRP, RDP I/C boots, SCT with Inovative, 14.0@96.4MPH
01 X 7.3, Dp, Cass 238/80 Hybrids, Terminator Dual pumps, TNBB, TE thermostat, ARP studs, Fluidampner, RDP 6637, RDP boots *** Big Thanks To RiffRaff Diesel Performance ***
  #7 (permalink)
Old 04-21-2011, 11:30 PM
Riffraff Performance's Avatar
Riffraff Performance Riffraff Performance is offline
PREMIUM SPONSOR
Riffraff Performance has a brilliant futureRiffraff Performance has a brilliant futureRiffraff Performance has a brilliant futureRiffraff Performance has a brilliant futureRiffraff Performance has a brilliant futureRiffraff Performance has a brilliant futureRiffraff Performance has a brilliant futureRiffraff Performance has a brilliant futureRiffraff Performance has a brilliant futureRiffraff Performance has a brilliant futureRiffraff Performance has a brilliant future
/pages/Riffraff-Diesel/103160771064 riffraffdiesel
Here is a link that may help you.
Riffraff Diesel: HPOP/ Related
  #8 (permalink)
Old 04-22-2011, 06:06 AM
bfife's Avatar
bfife bfife is offline
still plays with trucks
bfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to behold
get those lines changed boys and girls, there is NO good time for them to blow! Been there done that, once in NV and again in AZ. Bonus is the new updated ones don't have that nasty exposed braid to tear the skin off your arms next time you're under the hood. As far as removal goes, patience and persistence will win the day.
Barney
__________________
some think I'm dumber than a bowl of soup! some don't. both groups are right.
02 F550 380hp/800Tq
  #9 (permalink)
Old 04-22-2011, 08:17 PM
dagren99 dagren99 is offline
dagren99 is gaining momentum as a positive member of FTE.dagren99 is gaining momentum as a positive member of FTE.
Hmmm saw the 100k "maint interval" listed - got 109 on my 00 guess - I'll be hunting for some new HPOP lines
  #10 (permalink)
Old 04-22-2011, 09:24 PM
Franko72's Avatar
Franko72 Franko72 is offline
Molon Labe
2004 Honda VFR800 Vtec
Franko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud of
sunstatefranko Baconator 2000
Quote:
Barney
Good tip Barney, 253k on mine and I'm heading to NJ tuesday....
__________________
Early '99 F350 Lariat 2WD 7.3, BTS Trans w/ 6.0 cooler, BTS tunes, 6637 w/Riffraff cover, 4"MBRP, Isspro EV2 gauges, Ranch Hand, 2"leveling kit. HPx, FRx, Coolant Filter, Hutch,Harpoon, NVK5, T-500, Rosewood stage 1's,
Frank, PAA#99
B.E.S.T. map
  #11 (permalink)
Old 04-22-2011, 10:56 PM
2000 Mazda MPV
My Garage
$130-154 a pop from Ford, found them on Ebay for a instant buy for $100 for the pair... Just in case your looking for them... Search HPOP 7.3 diesel and they should come up. Think the guys located in Indiana...
  #12 (permalink)
Old 04-22-2011, 11:11 PM
2002 Ford F-350
Quote:
They are used, and one of the ends has a damaged protective ring cover.
__________________
Ken
  #13 (permalink)
Old 04-23-2011, 03:13 PM
2000 Mazda MPV
My Garage
Smile
Go to your local International dealer and give them the IH part numbers...
Left bank was only $75.00 and the right side was $81 with no shipping charges...I pick them up Wed Morning... with tax $162.00 thanks for the info...Somebody shared the IH parts manual on the Ford Enthusiast website and I used that...
HPOP hose Right Bank 1880061C1
HPOP hoseLeft bank 1880070C1
  #14 (permalink)
Old 04-23-2011, 03:26 PM
big poppa's Avatar
big poppa big poppa is offline
big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.
Are the ones you got the older stock lines are the newer ones Barney spoke of ?? Just wanted to know..
__________________
Mike's 03 F-250 7.3 CC SB XLT 4x4 Auto and just joined the 200,000 mile club and counting. PAA#26 Wife's: Whoops, I mean an 08 (Explorer) Eddie B. 4.0 v6 4x4 91,000 http://www.ford-trucks.com/forums/si...ic511779_3.gif
  #15 (permalink)
Old 04-23-2011, 03:45 PM
2000 Mazda MPV
My Garage
I'm assuming older; this line has the old IH part # on it......I'm second owner...220K miles on it...they are braided lines and the line blew through the side and even split the braiding...I noticed it had a oil leak a while back but just assumed a valve cover leak...driving home thurs night, it popped and just quit running...??? I'm assuming just replace lines and check fluid levels and then fire it up...Just got a lead on NAPA building the hoses too for alot cheaper but not going to make it there b4 five pm...have to wait till Monday on that...fill you all in if I find another option...We used to have hoses made through a Gas/Lube place for Hyd and they are lots more pressure then these and I don't remember paying anymore then $20-30 for those hoses....
Tags
2000, 73, disconnect, f250, high, hpop, line, lines, oil, pic, pressure, pump, quick, remove, removel, tool
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
