1977 build thread with pics
Old 08-04-2012, 09:07 AM
teds74ford's Avatar
teds74ford
teds74ford is offline
If I remember correctly, you are supposed to pull the pin out in the front of the prop. valve when you bleed. I used a suction bleeder when I did my other truck and it worked great. Other than that, not sure why you would be getting fluid back.
  #77
Old 09-23-2012, 12:36 AM
2002fx4122's Avatar
2002fx4122
2002fx4122 is offline
I try that next time around but I still havent fixed it. Working on this truck has been alot slower that I would like, now that work is done school has started but I'm coming back as much as I can to work on the truck. This weekend I decided the rear springs need new bushings since all the other bushing have been replaced with Energy Suspension bushings. So I got the leaf springs out which I though was going to be the hard part but I was wrong. Does anyone have any creative or good ways to get the old bushings out of the leaf springs?
Also since I have to order the bushings most likely from Bronco graveyard I was going to get the floor boards and cab corners so I could take the truck to the body shop and get those out of the way. But I got to thinking is there a better place to get patch panels like this from? I've heard stuff from LMC is pretty thin but I haven't heard anything about Bronco Graveyard.
  #78
Old 01-14-2013, 04:37 PM
whc8100's Avatar
whc8100
whc8100 is offline
How close do those headers come to the front drive shaft? Thanks.
  #79
Old 01-14-2013, 05:05 PM
2002fx4122's Avatar
2002fx4122
They do come pretty close, they come close to alot of things actually, Also when I had exhaust put on it they had to make a pretty sharp bend to get the driver side pipe to the passenger side so they could run them down for duals.
  #80
Old 01-14-2013, 07:08 PM
whc8100's Avatar
whc8100
whc8100 is offline
Thanks for your help. It seems all chassis headers for these trucks have some sort of fitment trouble. 3/4 length ones look like they give the most room, but their only shorties. If that even matters much for a mild 460.
mwoj
285
03-17-2024 06:52 PM
Powerhour
1947 and Older Ford Trucks
40
01-21-2019 02:24 AM
Ravenjinn82
09-11-2015 02:08 PM
Rockaholic
85
02-10-2012 08:02 AM
iconoplast
06-11-2010 01:43 AM
Quick Reply: 1977 build thread with pics
