rear fuel tank straps?
Old 04-21-2011, 07:04 PM
GHeTTo JOe's Avatar
GHeTTo JOe
GHeTTo JOe is offline
ok i need to replace my rear tank and went to remove the skid plates to find the tank held up by only the two piece plate. is this how it should be or should there be the straps and then the plates or was the plates an optional way of hanging the tank?
Old 04-21-2011, 07:08 PM
SideWinder4.9l's Avatar
SideWinder4.9l
SideWinder4.9l is offline
Skidplates, then the straps....The straps have a foam-ish like strip that keeps the strap from rubbing holes into the tanks...
So yea, the straps are the things that should be touching the tank, and the plates should bolt onto them, etc.....
Old 04-21-2011, 07:10 PM
GHeTTo JOe's Avatar
GHeTTo JOe
ok i just came across a thread they mention straps on the topside of the tank?
Old 04-21-2011, 07:14 PM
SideWinder4.9l
They're are 2 sets; Top and Bottom....Undo the 2 nuts and the lower straps will fall away, and so will the tank...Make sure not to let it just DROP, cos the plug on the top will tear up.....Otherwise, very simple...PB Blaster will be your friend....
Old 04-21-2011, 07:17 PM
SideWinder4.9l
The top straps are mounted to the crossmember IIRC....While you have the lower straps off, I'd go ahead paint them....To pretty them up, and to ward off rust....
Old 04-21-2011, 07:18 PM
GHeTTo JOe's Avatar
GHeTTo JOe
ok so napa shows only one set are they the same
Old 04-21-2011, 07:27 PM
SideWinder4.9l
Not really sure on that one....The upper ones have a "Bolt" that the lower one slips over, and a nut holds that together, so no....I don't think they are the same....My 92' and 94' had the tank straps that the lower ones simply slide over the "Bolt" and the 4 nts fasten the whole tank up...
Old 04-21-2011, 07:31 PM
GHeTTo JOe's Avatar
GHeTTo JOe
do you have the skid plates also?
Old 04-21-2011, 07:36 PM
SideWinder4.9l
No....Just the straps...lol
Old 04-21-2011, 09:53 PM
deeznuts822's Avatar
deeznuts822
deeznuts822 is offline
Your upper straps should be fine, they are not very hard to change if you do the bad one first
rdpickett406
1978 - 1996 Big Bronco
04-25-2017 05:43 PM
beersy50
10-11-2014 10:17 AM
NismoGriff
1997 - 2003 F150
08-15-2011 09:18 PM
John D in CT
16
12-01-2010 11:34 PM
92mnfordtrk
44
10-11-2008 01:15 AM
Quick Reply: rear fuel tank straps?
