Replacing serpentine belt
92 F150 with the inline 6 300 and air
Help please. The existing belt is frayed and cracked, need to replace it.
Picked up the new belt and have tried a number of times to install it. Can’t get it installed, like it is to short
Checked the length of it against the old belt. Old belt is slightly longer, inch to inch and a half, sure this is expected as it is old and stretched.
Any tricks or tips installing the belt?
Seems like I replaced the belt when I purchased the truck several years ago and don’t recall having any problems putting it on.
Thanks!
Thanks!
as I recall, mine CAN go on 2 ways, or so I was told.
Water pump may even spin backwards?
Might have all been an old timer joke since it was my uncle who told me that.
so as I was drawing a diagram on the inner fender with a magic marker,
I bumped my head near a sticker that shows it exactly.
Hopefully a nice big lever will get that spring loaded tensioner out of the way and the belt goes on withOUT your fingers or glove.
It sounds to me like you may have the wrong belt. 1" to 1 1/2" is a pretty big difference...belts stretch over time, but not that much. What is the part number on the new belt? Is the part number on the old belt still legible?
The numbers were completely gone from the existing belt.
Went to O'Reilly Auto Parts and they were very helpful. They tried the belt I had, had the same issue. Looked thru the stock and tried on 5/8 of an inch longer, still no go. Tried another that was a full inch longer and it fit.
Thanks for all the suggestions
Big Skier
31
02-27-2019 07:21 AM
Nigma
07-06-2016 05:12 PM
seattle smitty
13
06-06-2016 04:22 PM
granny_rocket
01-26-2016 12:14 PM
