How long does a bad torque converter last??
im pretty sure my torque converter is bad in my E4OD and it has been for at least 5,000 miles it shudders and sort of tugs and pulls into gears i have put dr tranny shudder fix in which has helped some....
my question is how long will a tranny last with a bad torque converter?
or am i running on borrowed time
If its bad, its bad now. It will only get worse. Depending on how it's failed it can overheat and burn the fluid causing the transmission to slip, burning up the frictions and steels. Once that happens it's time for a rebuild, and the lines and cooler(s) will need to be flushed to remove the debris and burned fluid. I'd have it changed ASAP along with flushing the transmission, lines and cooler. You don't want any possible debris in there.
I'd simply drop the tranny, and do it that way....
Here's some info to chew on....
-Tightening the Drain Plug back...
E4OD corque converter drain plug - Diesel Forum - TheDieselStop.com
-Refilling the TQ Converter...
https://www.ford-trucks.com/forums/8...r-on-e4od.html
on
even if it's just a budget used one.could mean keeping your trans around much longer.
here is what happens when they come apart:
https://www.ford-trucks.com/forums/1...some-pics.html
your another reporting problems with it way up there in 230k+ miles.
kinda makes a feller wonder just how failure prone stock converters really are doesn't it lol.iv never had any trans last so long.
rpatrick
03-21-2012 06:26 AM
f-superduty
17
02-16-2007 05:51 PM
Uglyhat
10-24-2005 05:32 PM
Sudsrat
11-02-2004 01:58 PM
