390 Transmission options - Ford Truck Enthusiasts Forums
Old 04-21-2011, 07:59 PM
1994F2507.3L's Avatar
1994F2507.3L 1994F2507.3L is offline
1994F2507.3L is gaining momentum as a positive member of FTE.1994F2507.3L is gaining momentum as a positive member of FTE.
what are the options for transmissions on a 390? we have a 390 sitting in a truck we are planning on putting back together with a 351. we have a early 80's 3/4 ton truck and transmission that was a 400 but the guy we bought it from blew the engine. would it be possible to take the 390 and bolt it up to the 400 transmission.... the trans we have for the 390 is a 2wd and need a 4x4 we don't have a use for a 2wd..... all farm use.
im a diesel guy and don't know much about the gassers
Old 04-22-2011, 01:08 AM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
The 390 is the FE series and will not bolt up to a 400 or any of the 351 motors. (C, W, M--M is same as the 400 for bell pattern)
If you are only going to use it for farm work, find a C6 4x4 trans in the FE pattern. Millions served, so you should be able to find one from late '60s to '76 truck.
If you are talking manual trans, then a 4 speed truck trans will bolt to the 390 with the correct truck bell. Again, lots of those out there, 352, 360, 390, any one will do as long as it is '66 or newer.
Old 04-25-2011, 08:27 PM
YoungMT Hick's Avatar
YoungMT Hick YoungMT Hick is offline
YoungMT Hick is starting off with a positive reputation.
so its right that the C6 cant change bell housing? Not that knowledgable in Trans. How do you know that a C6 is made for the FE series. Will a C6 match all FE's if built for the FE's?
Old 04-25-2011, 09:40 PM
C6 case and bell is one piece. Unless you are a magician with a welder and are a machinist to boot, you can't change it.
FE bell pattern: Took me a while, but scroll down here and you'll see the patterns:
FordFE Forum Faqs
The FE C6 will fit all FE's.
Last edited by 85e150six4mtod; 04-26-2011 at 01:08 AM. Reason: remove mt bell depth reference.
Old 04-26-2011, 10:42 AM
69cj's Avatar
69cj 69cj is offline
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
FordFE Forum Faqs
Excellant info. Thanks, Mike
Old 04-26-2011, 10:57 AM
Greenford100 Greenford100 is offline
Greenford100 is starting off with a positive reputation.
I have a 390 engine, and I run a c6 transmission through it. I would go that route, but if you think the 400 would bolt up right then go for that.
Old 04-27-2011, 06:31 AM
jowilker's Avatar
jowilker jowilker is offline
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
Quote:
C6 trannys are 1 piece cases. While you can run a C6 behind the engines as you described, they can not be swapped between engine families. The bell must match the engine that you want to bolt it to.
Past that I agree.
John
2wd to 4wd swap stromburg 1973 - 1979 F-100 & Larger F-Series Trucks 3 10-11-2012 10:43 AM
390 or 460 jseim44 1973 - 1979 F-100 & Larger F-Series Trucks 25 03-22-2012 08:44 PM
I'll probably go to H*ll for tihis but... CheeksMcDuke 1973 - 1979 F-100 & Larger F-Series Trucks 43 01-21-2010 02:52 PM
79 400 to 75 390 swap mdog1596 1973 - 1979 F-100 & Larger F-Series Trucks 7 01-17-2010 04:38 PM
what engines were available in '79? kadrocker 1973 - 1979 F-100 & Larger F-Series Trucks 29 05-22-2009 04:14 PM
Tags
2011, 360390, 390, 427, 4x4, 94, engine, f250, fe, ford, options, trans, transmission, transmissions, truck, upgrade
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
