Want a TALL liftgate? Forget 4x2 lift supports.
In case it helps others, I replaced my 4x4 rear glass lift supports and now have 6'7" to the bottom of the pull handle in my 05 Excursion fitted with RAS so no longer hit my head. Folks down to maybe 5' tall should be able to reach the pull handle and folks up to that 6'7" mark have no chance of hitting their head. I didn't measure it, but I'd guess it would be about 6'11" or so from the ground to the metal on the liftgate.
The extended length of the 4x4 lift support is 14".
The extended length of the 4x2 lift support is 14.72".
The extended length of these is 15.87"!
There is another support available with an extended support length of 15.25".
The liftgate will support all the way up to 16.5" before hitting the roof of the vehicle. Someone 5'4" can reach the pulldown handle all the way to 16.25". The only thing to watch out for is the liftgate hitting the roof of your garage if the ceilings are low.
Lou Fishman is incredible to work with. Highly, highly recommended.
$22.05 each.
Lift Supports
$22.05 each.
Lift Supports
I believe that the 4x2 supports only raised the hatch a few token inches - I would think that folks in the 5'11 on up range would still hit their head with that solution.
Liftsupportsdepot.com didn't carry a longer than 15.87" lift with the required compressed length, but these particular lifts take away any and all issues for 99% of folks. Given that the hatch is now angled up at maybe a 30° angle, even any rain water is diverted nicely now.
The OEM supports are a joke.
