Want a TALL liftgate? Forget 4x2 lift supports.
#152
Sent from my Galaxy Note 3 using IB AutoGroup
#154
#155
Great thread I wished I would have seen this 2 weeks ago. After not finding any lift struts at local auto parts places I had Ford replace them while they were replacing the rear ac module. I'm tall and would have loved the extra clearance of these struts. Oh well anything is better than using my head to hold up the hatch while loading stuff.
#156
I see you had the same "problem" I had. The struts say right on the side that you should install them with the shaft down when in the closed position. The tubes don't clear the body in that position, so you have to install them with the shaft facing UP while closed. It's a minor difference in terms of fitment but may reduce the life of the strut in adverse weather areas. I'm in Southern California so I expect I'll probably see no difference either way.
Last edited by sfoltz; 01-08-2014 at 08:01 AM. Reason: longer supports are 15.87" NOT 15.67", sorry
#157
#158
Finally got my eX back from headstud upgrade to ARP so that I could install the lift gate upgrade - love it! No more hitting my forehead grabbing stuff out of the rear hatch. Original shafts were also installed tubes down and shafts up. So, I see no issue with the upgrade being installed the same way. I added some grease to the mounting stud joints and I hope that's ok. Figured it would keep things quiet.
#163
My struts stopped working today ordered the 15.87" lift version
as posted in the initial post (an many others).
6421EX part # (both on Amazon and Lift Supports Depot)
$34 + 7.65 shipping from Amazon (Lift Supports Depot) for the pair.
Pretty much same price on both sites, but 1/2 the shipping on amazon
#164
#165
They just arrived at my door. The box was jacked up (was delivered by a guy in a Uhaul van) but the shocks seem to be ok. Plan to install this weekend and will give an opinion later...
