Want a TALL liftgate? Forget 4x2 lift supports. - Page 5 - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
  #61
Old 02-14-2012, 07:12 AM
69oiler 69oiler is offline
69oiler is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Shepherd2 View Post
I installed a set and in less than a month they couldnt keep the hatch up anymore .
Interesting, mine are still working strong after several months.
  #62
Old 02-14-2012, 07:22 AM
ecoastkid ecoastkid is offline
ecoastkid is gaining momentum as a positive member of FTE.
Just ordered mine.
I was a bit annoyed at almost 10 dollar shipping but then as I was about to check out, it had a thing that said "Use this coupon code for 12 percent off NYE2012" so that made me feel a bit better about it. Cant wait to get these on.
2 Lift Supports 6421/48154 $44.10
Subtotal: $44.10
Shipping: $9.94
Tax: $0.00
12% savings: -$5.29
Total: $48.75
  #63
Old 02-14-2012, 07:24 AM
Perhaps just one of them is defective. See if you can test somehow and give the company a ring. Not saying it doesnt suck, but these things happen. Hopefully the company will step up for you.
  #64
Old 02-14-2012, 02:05 PM
Shepherd2 Shepherd2 is offline
Shepherd2 has a good reputation on FTE.Shepherd2 has a good reputation on FTE.Shepherd2 has a good reputation on FTE.
He did send me a replacement set but I havent installed them yet. The customer service is excellent no question. Funny thing is he recommended they be installed upside down because they last longer.
  #65
Old 02-14-2012, 03:18 PM
Well thats awesome to hear. Hopefully this set last longer for you.
Thats pretty interesting that he suggested that. When they say upside down, which way is that oriented? I'm picturing the rod facing down and the fat part up so maybe moisture doesnt run down into it? (or is that right side up..haha)...
  #66
Old 02-16-2012, 10:46 PM
Dmntxn77's Avatar
Dmntxn77 Dmntxn77 is offline
Dmntxn77 is starting off with a positive reputation.
I just signed the papers on my X yesterday, found this forum last night, and read this thread right off the bat. Since my rear hatch was VERY hard to lift, I figured that I might as well start my modding here.. lol
And, since I dont like to wait, I found some 4x2 lift supports locally that did the trick.
They are Srong Arm Lift brand part #E4139 and they extend to 14.72"s. I didnt measure before and after, but Im sure they gave me at least 2"s more height out of my hatch.
I got them at my local Advance Auto for $24.29 each. However, with a coupon code I ended up paying only $16.20 each.
Thanks for the tip!!
  #67
Old 02-16-2012, 11:37 PM
robert_l_ross's Avatar
robert_l_ross robert_l_ross is offline
robert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputation
Quote:
...how much clearance do you have on your front springs (spring to bump stop)? That might be your next mod!
  #68
Old 02-16-2012, 11:45 PM
Dmntxn77's Avatar
Quote:
Dunno yet... I will check tomorrow. Whats factory?
  #69
Old 02-16-2012, 11:50 PM
I don't know that anyone really measured when they bought their Excursions new back in 2000-2005...but if you are less than 1 1/2", it's probably time to do a spring swap. http://www.ford-trucks.com/forums/11...p-by-step.html
Sorry guys! Back to the OP.
  #70
Old 02-16-2012, 11:57 PM
Dmntxn77's Avatar
Yeah, sorry about the hijack... One question though. I cant get PMs yet, so feel free to post it on my profile. I read over your thread a bit but I havent figured out how to tell if I have a V or B "code" X.
  #71
Old 02-17-2012, 12:02 AM
You don't...the V/B springs are off of F250's/F350's. V codes are front springs, B codes are back springs. Your stock spring code will be on the B pillar sticker.
Unless of course the owner did the mod before you bought it. If he did you probably will already have plenty of clearance.
  #72
Old 02-17-2012, 02:07 AM
trucktech trucktech is offline
trucktech is starting off with a positive reputation.
Just ordered a set can't wait for them to show up!
  #73
Old 08-16-2012, 02:36 AM
nsmith001 nsmith001 is offline
nsmith001 is starting off with a positive reputation.
I got a set of the supports. I have some questions:
1 Should you be able to compress them by hand?
2 Do you pry the old ones off or remove the spring clip first?
3 How do you remove the spring?
I have a piece of 1/2 in pvc pipe to lift the hatch (the hatch has never lifted itself or stayed up even after I replaced them); is this sufficient to support the hatch while installing the new supports?
Thanks, Norris
  #74
Old 08-16-2012, 07:34 AM
st8yd's Avatar
st8yd st8yd is offline
st8yd is gaining momentum as a positive member of FTE.
No way you could compress them by hand.
pry the spring clip up as I recall, like most lift supports.
the pvc will probably work.
I don't recall using anything to support it.
Take one side off, then I just loosened clips on both ends of the old remaining one and new one.
Lifted it up took one off and put new in place.
Then put new one on other side.
  #75
Old 08-16-2012, 09:47 AM
FICMrepair.com FICMrepair.com is online now
SPONSOR
FICMrepair.com is a splendid one to beholdFICMrepair.com is a splendid one to beholdFICMrepair.com is a splendid one to beholdFICMrepair.com is a splendid one to beholdFICMrepair.com is a splendid one to beholdFICMrepair.com is a splendid one to beholdFICMrepair.com is a splendid one to behold
I'd think that 1/2 PVC would bend under the weight, but you'd have to try it. That lift gate is HEAVY. Better would be a 2x4 or a friend to help the PVC hold the weight.
That said, you could just hold it up with something yourself (some have used their head...) as you take the clips off and replace the old arm.
Good luck! You'll really like the result.
__________________
Ed
Ed@ficmrepair.com
2005 Excursion 6.0 PSD. RAS, 4" MBRP T409, Edge Insight CTS, ScanGauge II, coolant filter, DELO ELC, upgraded FICM from FICMrepair.com, SCT, blue spring upgrade, trans bypass filter, Rancho 9000XL's, SS ESOF lines, Rotella 5W40, Clifford Remote Start, Prodigy.
Platinum ETIS Data shows "Less Electronic Locking Differential"???: Wealthk1 2017 Super Duty 13 09-02-2016 06:16 PM
Just a Safety reminder..... housedad Excursion - King of SUVs 10 06-23-2014 02:38 PM
1973 F350 CREWCAB desert/dunes budget build by DirtyDeedsIndustries dirtydeeds 1973 - 1979 F-100 & Larger F-Series Trucks 289 04-26-2013 03:01 PM
Funny hatch strut story... Bogus Exception Excursion - King of SUVs 18 02-03-2012 01:38 PM
Garage door header 2Wise4aGM Garage & Workshop 13 11-08-2003 02:07 PM
Tags
2002, 4x2, duty, escape, excursion, ford, gate, heavy, lift, lifted, liftgate, struts, support, supports, tailgate
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
