Want a TALL liftgate? Forget 4x2 lift supports.
Old 01-12-2012, 03:23 PM
Peace2Peep's Avatar
Peace2Peep
Peace2Peep is offline
Yeah! I did it! I love it! And HECK YEAH that hatch is HEAVY! It does take two people to do this WORD to the WISE!
  #47
Old 01-12-2012, 03:55 PM
robert_l_ross's Avatar
robert_l_ross
robert_l_ross is offline
I happened to have one of those extendable arms you attach a paint roller to for painting tall walls...fiberglass with notches and a pin. That worked perfect for me - but trust me, I worked QUICKLY to get that first strut on - constantly thinking at any moment it would slip out and decapitate me! It can be done, but it's nerve wracking!
  #48
Old 01-12-2012, 05:47 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
I just had my 6'0" 19 year old son (now 20) hold it up and told him to quit complaining!
Stewart
  #49
Old 01-12-2012, 06:57 PM
Junx69's Avatar
Junx69
Junx69 is offline
Thank goodness I had a stack of 2x4s cut to use as dividers on my pickup's bed liner sitting next to me when I did this. Took that first strut off and holy crap! Grabbed a 2x4 and held it up as I took the 2nd one off. It held it just high enough for me to snap the new ones on. If you don't have someone to help you had better definitely use some kind of support.
  #50
Old 01-12-2012, 11:20 PM
03-6L-X's Avatar
03-6L-X
03-6L-X is offline
Who needs extra help. If you just prepare properly, all you have to do is stand there use your head and do one side at a time. And yes it is heavy, but when you are finished it is a load off your mind.
  #51
Old 01-13-2012, 06:00 AM
Junx69's Avatar
Junx69
Junx69 is offline
One side at a time doesn't quite work with these longer struts since you have to raise the lift gate higher to attach the new ones. The stockers won't stretch that far so both have to go. Oh look at me, Mr. Literal.
  #52
Old 01-13-2012, 10:36 AM
jasonodsky's Avatar
jasonodsky
jasonodsky is offline
I used a 2X4 to prop the tailgate in fully open position and removed both old struts. Then attached the bottoms of both new struts. Then straddled the back doors (one foot on the bumper, on in the cargo area) and lifted slightly with my back against the liftgate. Did all the lifting with the legs. Popped in one side, then the other.
Was a very easy one person job with a little planning. But I'm stubbornm 5'9" and 135 lbs.
  #53
Old 01-13-2012, 11:31 AM
Excurvelle's Avatar
Excurvelle
Excurvelle is offline
If you use the 2x4 on a gravel or grass area you can easily slide the 2x4 in towards the truck, raising the hatch and it will bite into the ground so it does not slip. Make sure the new support is already attached to the body on one side and the clip is released to allow it to connect to the socket on the gate before doing the other side. I used a ceremony flag pole, it was tall enough to do what the 2x4 did.
  #54
Old 01-13-2012, 04:17 PM
robert_l_ross
I did similar but reverse...I attached it to the hatch side first so they would hang straight down and not rub the paint...
  #55
Old 01-13-2012, 08:32 PM
bobalonius's Avatar
bobalonius
bobalonius is offline
I just finished putting on a pair of these struts and holy crap, I love the height difference. That place had great customer service too.
  #56
Old 01-26-2012, 07:49 PM
thegorilla's Avatar
thegorilla
thegorilla is offline
Awesome tip, repped! I wish I would've seen this 3 weeks ago, before I ordered the 4x2 struts from Amazon and put them on. D'oh!
Another install method: I used an adjustable telescoping trekking pole to hold the gate while I removed both old struts. One of the new ones was enough to keep it up while installing the second one.
  #57
Old 02-13-2012, 08:24 PM
ATG_Tuning's Avatar
ATG_Tuning
ATG_Tuning is offline
BUY THESE!!!! Best mod i have done!
This is a no brainier. Cannot believe the difference. I would post pics, but there are enough already, just get them. I am mad that i waited as long as i did.
Thx to OP for the thread. My shocks needed to be replaced anyway, so this just made sense. I was nervous, but i cannot believe Ford dropped the ball on this....these should be factory.
  #58
Old 02-13-2012, 08:39 PM
st8yd's Avatar
st8yd
st8yd is offline
I got the one's for the 2wd from Advance auto. While the lift height is sufficient, they are getting weak and slow to open and not even a year old.
  #59
Old 02-13-2012, 09:54 PM
FICMrepair.com's Avatar
FICMrepair.com
FICMrepair.com is offline
Former Vendor
I'm just glad to have helped so many folks out! Repeatedly clobbering yourself in the head gets old!
When I installed mine, I used a 2x4 and a hydraulic floor jack to customize the height that the lift gate stayed at during the install. It made line up a snap!
Ed
Ed@ficmrepair.com
  #60
Old 02-14-2012, 03:05 AM
Shepherd2's Avatar
Shepherd2
Shepherd2 is offline
I installed a set and in less than a month they couldnt keep the hatch up anymore .
Quick Reply: Want a TALL liftgate? Forget 4x2 lift supports.
