What's the RTV everyone uses for compressor wheel housing?
I need to swap my compressor wheel. I've read talk about RTV to seal up the housing but I haven't read anything brand specific. I did read a couple posts saying to use Ford gray RTV, but I'd sure appreciate it if someone has a part number or name of that or another RTV that works as well.
I may or may not have an oring in there, but the last housing I took apart the oring was trashed so I am assuming this one will be too if it has one. I do see some RTV on the housing seams on the one I am about to pull apart.
Thanks muchly-
Chris
Thanks muchly-
Chris
And there in lies my question. lol Thanks for the replies guys. If I don't need the ford stuff $$$ then I'd rather save the money and get some hitemp sealant. If I need the ford rtv for sure for the turbo then I'll spend the money and get it. I read about the ford stuff being formulated to stop the foaming probs, but since it's not going to be covered in oil (I did the CCV mod) I wonder if I need a $30 5oz tube of the ford stuff.
C-
C-
Pete, t-31 is what i got from ford when i asked for the gray rtv. i got it to seal up my idm when i do the mod.Did i get the right stuff? Is there a different gray rtv from ford that you guys are using to reseal the idm?
Apologies. I was thinking TA-30 and typing TA-31. The Ta-30 is what I was thinking about. So yes you got the right stuff. Can't find a temp spec on the TA-31.
Here is a good link for all chemicals Ford.
If you want my opinion use the o-ring. I don't know why some of the OBS turbos have RTV on them but if your o-ring is in good condition I don't see the need.
Riffraff Diesel: Garrett TP-38 Compressor Housing O-ring
Riffraff Diesel: Motorcraft RTV Silicone Sealant
hail destroyer
09-28-2016 08:33 PM
hail destroyer
09-28-2016 08:26 PM
Necromancer
01-25-2016 08:37 PM
