Blown front seal E4OD - Ford Truck Enthusiasts Forums
Old 04-21-2011, 02:48 PM
avenge avenge is offline
avenge is starting off with a positive reputation.
What would cause to a front seal to blow out? I just put in a used front pump with new seals, bearing and gasket. The pump came out of my other transmission that had a torque converter go out. After it was done it was dry as a bone only thing I noticed was a slight vibration in drive when stopped.
Would a bad or blocked pump (drain back valve) cause it? What about a blocked cooler line or backwards cooler line?
Anyone know which side of the radiator on a 95 E150 van is the trans return line?
I ask because I had to cut the lines and forgot to mark which was which but thought I guessed right and also heard it made no difference.
Need help with pricing - selling carver94f350 N. California Chapter 4 10-21-2015 03:29 PM
Replacing front pump seal, who carries the updated Viton one? jakegaisser 1987 - 1996 F150 & Larger F-Series Trucks 7 08-04-2015 06:47 PM
e4od leaking at bellhousing, front pump seal still in there, its new, what should I check? jakegaisser 1987 - 1996 F150 & Larger F-Series Trucks 0 07-25-2014 11:03 PM
Go for an ESP Ford Warranty? Jack.Chris250 1999 to 2016 Super Duty 22 07-01-2012 12:05 AM
C6 trans cooler line... which is out/in...? zsir Clutch, Transmission, Differential, Axle & Transfer Case 5 05-31-2004 03:38 AM
Tags
blow, blown, drive, e4od, ford, front, line, pump, radiator, return, seal, side, stopped, transmission, van, vibration
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
