Help! - Ford Truck Enthusiasts Forums
Help!
Old 04-21-2011, 02:34 PM
Jaime74656's Avatar
Jaime74656 Jaime74656 is offline
Jim
Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.
Help!
Ok I was driving today like normal with my truck and suddenly on the motorway i taped the breaks to switch off cruise control and my truck is now making a very bad screeching/squeeking noise!! don't know what it could be or what to do to fix and im concerned about driving it more for the issue could be getting worse with it!!! any suggestions of how to fix? it only happens when the truck is moving forward, not sure about reverse tho...
Old 04-21-2011, 03:50 PM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
Could be a small rock caught between the rotor and rotor dust shield but I would have thought a good bet would be worn brake pads.
Could also be a bad wheel bearing.
If the noise is coming from the back then it could be worn brake shoes or broken shoe hardware.
Try to find out what corner the noise is coming from and pull the wheel and have a look.
Old 04-21-2011, 07:26 PM
Jaime74656's Avatar
Jim
well I did just that and my worst tfears came true (thankfully i did it at pepboys) and as we pulled the drums off both rear breaks completely disentagrated in front of us thankfully i was in a parking lot...coulda been worse if i was on one of the local autopistas doing 100Km/h (60MP/h) like usuall...yeesh.....
Semi built 351m need help figuring out whats wrong. 77flareside 1973 - 1979 F-100 & Larger F-Series Trucks 15 08-27-2010 10:53 PM
Transmission problems braap.jeremy 1997 - 2003 F150 9 08-07-2010 07:02 PM
Volt meter delay? bass-n-fire 1994.5 - 1997 7.3L Power Stroke Diesel 49 07-18-2010 06:33 PM
What is broken? Cope Ranger & B-Series 8 09-01-2006 08:19 PM
whistle??? CRJ900 1967 - 1972 F-100 & Larger F-Series Trucks 6 04-12-2002 01:01 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
