How does this sound for a build? - Ford Truck Enthusiasts Forums
Old 04-21-2011, 01:34 PM
SideWinder4.9l's Avatar
SideWinder4.9l SideWinder4.9l is offline
SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.
Ok guys....After a LOT of careful thought, an research...Here is what I want to do to my truck...
Body-
-Repaint using the same color-Or a few shades darker.
-Fix the rusty holes with METAL replacement panels.
-Roll pan
-1Pc Headlights-Smoked
-LED Brake Light bar under the tailgate
-Red Polyurethane Body Mount Bushings
Engine-
-Camshaft/ Lifters setup for Idle-4,500 RPM's
-Possible Aluminum pulleys-Probably have to get some for a 5.0, and re-do the bolt holes.
-Paint the block, head, valve cover and intake manifold.
-Sidegap the plugs
-Port the Intake/Exhaust ports.
-Possibly shave the head/re-bore block to true specs.
-Remove SMOG equipment; It's already half gone, an no CEL.
-CAI routed from behind the front valance to the intake; Using a 302 MAF Intake Y-Hose....Already have it BTW.
-Remove the exhaust from the manifold flanges, and redo with 2" pipe down to a Y, and then up to 2-1/2" from the Y to behind the rear wheel.
Suspension-
-2" Lowering Coils in the front
-3" Drop Beams in the Front
-5" Axle Flip Kit in the rear/ I already have 2" Lowering Shackles in the rear
-Front and Rear Sway Bars
Drive Train-
-Hurst Shifter for shorter throws
-Centerforce Clutch for stronger pulling
-Possibly a Hydro-Clutch booster
-3.55 rear gears, it has the stock 3.08's right now
-Either a Limited Slip or Spool for the rear end
Now, is that too much? Just want to beef up the rear a bit, and put the power where the engine can do work, and not be stroking out......
I have contemplated a 302 swap, and still on the fence about it...
Thanks for looking guys, and if you see something I have missed, or could make use of, let me know...
-Wes
Blue Oval Saga Pt. II-Michelle SideWinder4.9l 1987 - 1996 F150 & Larger F-Series Trucks 620 08-19-2016 05:09 AM
Automatic E40D Swap to 5 Speed (Mazda M5R2) Ztitan 1987 - 1996 F150 & Larger F-Series Trucks 52 01-25-2015 10:55 AM
1975 F250 Super Cab Camper Special Myfreeford Vehicles for Sale 0 06-24-2014 12:31 AM
1972 Bronco in Georgia captradiator Vehicles for Sale 3 01-31-2013 09:22 AM
Simply Ethel.....*PICS* SideWinder4.9l 1987 - 1996 F150 & Larger F-Series Trucks 3 12-03-2010 11:09 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
