C5 transmission help. - Ford Truck Enthusiasts Forums
Old 04-21-2011, 01:26 PM
gotpiercings5 gotpiercings5 is offline
gotpiercings5 is starting off with a positive reputation.
The C5 transmission in my hubby's '83 F100 truck will not shift into reverse anymore. After about a year of owning the truck, it started to shift pretty hard when putting it into reverse. A few months later we lost reverse all together. Everything else works fine on the transmission. It shifts very smoothly into 1 -3. He has replaced the reverse servo, drained and replaced the fluid (no metal pieces were seen in fluid) and thats about it (so far). If anyone can help figure out whats wrong, I would really, really, REALLY appreciate it. Thanks so much!
86 f250 c6 transmission not shifting. waystro Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 07-26-2014 01:29 AM
C6 shifting hard into reverse Ken Blythen Clutch, Transmission, Differential, Axle & Transfer Case 15 06-11-2011 06:03 AM
Tranny issues after shift kit. customcreationsllc 1999 to 2016 Super Duty 7 05-09-2011 02:24 PM
Reverse shift wait time. amsett 1994.5 - 1997 7.3L Power Stroke Diesel 11 12-10-2010 01:17 AM
C6 transmission, no reverse. racsan Clutch, Transmission, Differential, Axle & Transfer Case 1 03-22-2008 07:47 AM
Tags
239, big, buy, c5, conversion, f150, ford, shift, specs, speed, trans, transmission, transmissions, truck, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
