Want to add Limited Slip Differential to '87 F350
Old 04-21-2011, 11:08 AM
hpfiend's Avatar
hpfiend
hpfiend is offline
Hey all-
We have a 1987 F350 with the 7.5L 460 v8 and 4 speed manual, 2WD. It has dual rear wheels however. It did not come with a limited slip differential and I was wondering if anyone knew what rearend was in it and where to get a limited slip carrier and gear set. We use it on the farm and it would be neat to think about using it in the snow/mud without having the tractor on standby.
Thanks,
Andrew
Old 04-21-2011, 01:49 PM
mdula's Avatar
mdula
mdula is offline
Since you said you use it on a farm, and if most roads are not paved you could do it the extreme cheapo way and weld together the spider gears and make it a locker. Very cheap and effecive, 4x4 guys have been doing this for years but HIGHLY not recommended if you drive on paved roads.
Your axle tho is likely a sterling 10.25 could be full float or semi float axles. https://www.ford-trucks.com/forums/8...-question.html
Old 04-21-2011, 02:16 PM
joshofalltrades's Avatar
joshofalltrades
joshofalltrades is offline
Since he has duals, its almost definitely a full floating axle, a quick look at it will tell you
Old 04-21-2011, 02:45 PM
Lazy K's Avatar
Lazy K
Lazy K is offline
Could be wrong but I thought the DRWs were D80 axles. A look at the axle code on the door sticker should confirm either way.
Old 04-21-2011, 02:58 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
For dually, i wouldnt even bother with a clutch limited slip. The extra tires get so much more bite, all it will do is slip. Get a locker or a gear limited slip
Old 04-21-2011, 03:06 PM
SideWinder4.9l's Avatar
SideWinder4.9l
SideWinder4.9l is offline
x2....A buddy of mine has a 3500 Series Chebby with a Detroit Locker....Pulls like a ****....454 w/ auto....
-Wes
P.S-The 454 seems a smidge underpowered for what it is....Seems to me like it should have some more ooph...
Old 04-22-2011, 02:37 PM
hpfiend's Avatar
hpfiend
hpfiend is offline
What am I looking for on the door sticker?
Didn't the factory offer limited slip as an option in 87?
We use the truck to pull a cattle trailer with cattle in it to auction and the truck has a dump bed added to it...
Our main problem is mud and snow so I don't know if the duals will have enough bite to spin the clutches in this particular case?
I bet that 454 pulls better than this anemic emission bogged 460!
Thanks,
Andrew
Old 04-22-2011, 02:54 PM
SideWinder4.9l
It will say "Axle"...There will be a #, 18, 19,etc....Some have H19, etc....
And it did ok....Was still anemic....lol he bought it for $1,600.....and it was a 95'....
Marioj87
2004 - 2008 F150
01-28-2016 05:19 PM
Platinum08
1999 to 2016 Super Duty
12-10-2014 09:39 AM
vettman
11-11-2011 07:12 PM
Bronco Billy
08-09-2010 07:30 PM
BoVan
27
03-24-2007 07:26 PM
Quick Reply: Want to add Limited Slip Differential to '87 F350
