Changing gear oil - Ford Truck Enthusiasts Forums
Changing gear oil
Old 04-21-2011, 10:09 AM
ChristopherN ChristopherN is offline
ChristopherN is starting off with a positive reputation.
Changing gear oil
I apologize for making so many threads lately. But work is boring this week.
Anyways....
I would like to change the gear oil in my rear end tomorrow but I'd like to know where the fill plug is for my truck, I have no stinking idea what kind of rear end I have but is there a standard spot for filling?
Also, what kind of gear oil should I use and how much?
Old 04-21-2011, 10:18 AM
Drew2010's Avatar
Drew2010 Drew2010 is offline
Drew2010 is starting off with a positive reputation.
a link I think is pretty informative.... boss does good work
8.8 Fluid Change and RockCrusher Cover - FSB Forums
he used a different cover, but its all pretty much the same, if you dont have a limited slip, then you dont need to add a friction modifier.
Old 04-21-2011, 10:28 AM
ok thanks!
oil question cpt.phil 1948 - 1956 F1, F100 & Larger F-Series Trucks 0 01-17-2011 05:55 AM
gear oil jimwilsonmasonry 1994.5 - 1997 7.3L Power Stroke Diesel 2 05-13-2008 08:32 PM
Changing oil in F350 rear end (no plugs) karljay Clutch, Transmission, Differential, Axle & Transfer Case 1 08-13-2005 10:34 PM
Emergency!!!!!!! bronco351 1978 - 1996 Big Bronco 29 04-14-2003 08:01 PM
leaking gear oil from rear driveshaft blueoval79 Clutch, Transmission, Differential, Axle & Transfer Case 2 08-01-2002 01:43 PM
Tags
1994, 2001, 87, change, changing, diesel, end, f150, f250, filling, ford, fords, gear, google, lube, model, oil, rear, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
