89 with a bad frame spot. Repair? - Ford Truck Enthusiasts Forums
Old 04-21-2011, 10:57 AM
fast_st fast_st is offline
fast_st is starting off with a positive reputation.
Have an 89 F250 4x4, just a whisker under 500k on the clock, on the passenger side front, right behind the shock, near where the brake line comes out the frame is paper thin and crumbling.
There is a little crease right there, runs top to bottom, but I think its a crumple point? I think my options are find a similar year frame to section bits from or whereas the top and bottom rails seem fine, cut out the flat frame side and fit/mig in a piece of plate, make a new hole for the brake line and bracket.
Any thoughts?
Tags
89, bad, f250, fix, ford, frame, repair
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
