94 F 150 4X4 Tranny Problem - Ford Truck Enthusiasts Forums
Old 04-21-2011, 10:20 AM
odellj odellj is offline
odellj is starting off with a positive reputation.
i just bought this 94 but I also have a 90 F-150 too. When i bought the 94 the former owner said that a shift kit was installed. The problem is that one day when I get on the gas it shifts so hard into 2nd that it sounds like it hits the floor board. The next day it might shift normal but when its in park or nuetral it has a ticking noise like a lifter tapping but its coming from the tranny. Now it doesn't do the tapping/ticking when it is shifting hard. It only does one or the other and I am really confused. Any help is appreciated.
Old 04-21-2011, 10:51 AM
timbersteel's Avatar
timbersteel timbersteel is online now
timbersteel has a good reputation on FTE.timbersteel has a good reputation on FTE.
Only a few suggestions..
What tranny in the '94? E4OD? AODE? AOD?
Check all tranny mountng bolts in the bellhousing to block; Remove inspection cover on tranny and look to see if the torque converter bolts are hitting the bellhousing OR if any are loose that attatch to the flexplate; could also be the signs of the flexplate cracked or any other number of things. Perhaps the shift kit wasn't installed correctly...Sure hope not..
Your best bet, IMO, is to make an appointment @ the tranny shop. Perhaps someone else has hit the same bump in the road as you have.
Let us know what you find.
Old 04-21-2011, 11:44 AM
Honestly I don't know what tranny it has right now. I did try driving it today to work with the OD turned off. When I did that it started slipping out of 4th gear. I guess I am looking at pulling it and doing a rebuild or replacement.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
