New starter grinding when driving? - Ford Truck Enthusiasts Forums
Old 04-21-2011, 07:33 AM
96F150HuntingTruck 96F150HuntingTruck is offline
96F150HuntingTruck is starting off with a positive reputation.
I have a 96 F150 4X4 5.0/302 Auto Reg Cab Long Bed that the starter was going out on so went down to my local OReilly's picked up a BRAND NEW not remanufactured, Ultima Gold starter, climbed underneath the truck pulled the old starter out, installed the new starter. Started right up like a champ. (Made sure to check the connections, all the wires look to be ok, no major rust or damage there, also hooked up the volt meter to make sure, getting 12.58 volts to the starter).
The issue is under a load and during regular driving I can hear the stater and/or flywheel grinding, not just a little, but quite a bit! Has anyone experienced this after replacing the starter with a brand new one? I'm not driving the truck around at this point because I don't want to do any damage to the flywheel, but really would like to get this thing fixed up quick. The old starter didn't grind at all, but definitely was on its way out, almost left me stuck in a parking lot were it not for the tried and true BFH (hit it with the hammer a few times and started right up and limped it home about 2 miles).
I've seen a few things on the net about getting some shims to put inbetween the starter and the bolt holes, but usually in the context of installing a remanufactured starter, would this also be the case with a new one? Visually inspected the flywheel and didn't see any visible damage or excessive wear, so I'm at a loss.
Any ideas?
Old 04-21-2011, 07:55 AM
douglpr42 douglpr42 is offline
douglpr42 is gaining momentum as a positive member of FTE.douglpr42 is gaining momentum as a positive member of FTE.
is it the right one ? different length for auto trans and manual. one to long will start motor but not disengage. also i had a bad solenoid on a topaz that would stick and stay engaged. please post what you find.
Old 04-21-2011, 10:37 PM
Got some starter shims from the autoparts store, going to try to install shims in various combinations to see what works.
Anyone got any other ideas???
If this doesn't work, going to request a motorcraft replacement and see if that is any different.
Starter Woes Buck-jobba Modular V8 (4.6L, 5.4L) 3 03-15-2016 08:39 AM
79 ford f 250 starter trouble captain1997 1973 - 1979 F-100 & Larger F-Series Trucks 9 09-27-2015 03:15 PM
89 f150 4speed manual starter/flywheel grinding noise tbemis 1987 - 1996 F150 & Larger F-Series Trucks 8 01-26-2015 04:04 PM
Truck almost didn't start this morning... starter grinding bad 90pioneer 1999 - 2003 7.3L Power Stroke Diesel 2 01-12-2014 02:51 PM
starter problems thumper869 1994.5 - 1997 7.3L Power Stroke Diesel 3 10-27-2009 01:17 AM
Tags
1986, 1999, 46l, 87, bronco, driving, engages, f150, f350, ford, grinding, grinfing, pictures, put, shim, starter, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
