Dana 60 outer shaft repair? - Ford Truck Enthusiasts Forums
Old 04-21-2011, 07:20 AM
1lilredwagon's Avatar
1lilredwagon 1lilredwagon is offline
1lilredwagon is starting off with a positive reputation.
Hey guys, I bought a d60 from a 94 F350 to do a ttb swap on my 96 F250. My question is weather or not I can use my ttb outer axle shaft from the short side if I can repair the damage on the existing shaft or if I need to source another one. You can see the damage caused by a bearing failure towards the yoke end of the shaft. I figured I could weld it up and have it spun down on a lathe. Link to photo below.
ImageShack® - Online Photo and Video Hosting
Old 04-21-2011, 11:24 AM
Bump bump bump
Tags
04, 2003, 60, axles, bearing, damage, dana, f350, ford, forf, outer, repair, video, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
