difficult to fill gas tank
Old 04-21-2011, 05:59 AM
powersmoked's Avatar
powersmoked
powersmoked is offline
The gas pump/hose keeps shutting off when I fill my tank. The problem is progressively getting worse. No Codes. Truck runs fine. I looked at the filler neck and filler hoses. They appear to be original but no obvious signs of an issue
Old 04-21-2011, 06:35 AM
03 Maz B23's Avatar
03 Maz B23
03 Maz B23 is offline
Clogged or pinched vent tube for the evap system.
Old 04-21-2011, 06:44 AM
powersmoked
Is that the 1" hose that runs from the filler neck to the tank or is it a hose that runs to the cannister and or engine?
Old 04-21-2011, 07:09 AM
03 Maz B23's Avatar
03 Maz B23
Just a guess on my part but think I would concentrate on the one going to the cannister. On my truck the evap canister is in the back . Yours could be different .Any chance you have had the bed off to work on the fuel pump? If so the hose could have been pinched on the reassembly.
Old 04-21-2011, 07:25 AM
powersmoked
Just a guess on my part but think I would concentrate on the one going to the canister. On my truck the evap canister is in the back . Yours could be different .Any chance you have had the bed off to work on the fuel pump? If so the hose could have been pinched on the reassembly.
I did have the bed off a year ago to do my hangers and shackles. Ifollowed the hose that runs front the vent at the top of the tank. It runs to a Y fitting one hose then goes to the canister over the spare tire and then other appears to run along the frame rail to the engine. I can't see any places that is crimped or crushed.
Old 04-22-2011, 07:16 PM
Phinxter's Avatar
Phinxter
Phinxter is offline
What year is it? You must have a restriction in the vent somewhere. sometimes spiders like to build nests in vent lines or the vent soleniod.
Old 04-24-2011, 09:26 AM
sfcwoodret's Avatar
sfcwoodret
sfcwoodret is offline
Also make sure the gas nozzle is all the way down inside the tank opening.
Old 05-11-2012, 05:32 PM
powersmoked
Ok so I finally got around to checking it out....I only had a few minutes but I pulled the 1"? hose off the metal filler tube and used compressed air down the rubber hose to the tank and then up the metal tube toward the cap. there is a screen in the metal tube......when i put the air down the rubber hose toward the tank gas came out of the 1" metal fill tube..........so I guess nothing is clogged in the tank or filler hoses.........(I checked and still have the problem)..the hoses were a little soft and a little flattened . I wonder if they are sucking in when I put gas in. I did not have anyone to help me pump as I looked at the hoses............does anyone know the actual sizes of the 2 hoses.........I can buy them online but I need to know the sizes.........when I have a chance I will pull the canister/evap hoses off and spray them...........all thoughts are encouraged.......TIA
*I discovered that if I hold the gas nozzle at 10:00 It works pretty good.
Old 06-02-2012, 09:11 AM
srteach's Avatar
srteach
srteach is offline
That indicates a clogged tank vent tube. Changing the position of the fill nozzle changes where the auto shut off vent (for the pump) picks up air. This indicates the vent tube (runs parallel to the fill tube to the tank) may be plugged and air is trying to come back up the fill tube.
Old 06-04-2012, 04:52 PM
g_k50's Avatar
g_k50
g_k50 is offline
Hoses are hooked up wrong, screen should be on the fill hose not the air vent hose.
hotrodfeguy
08-30-2014 12:02 AM
reddhawk
Escape & Escape Hybrid
01-07-2013 10:06 PM
sogath
05-12-2011 06:41 PM
Diesel_Brad
07-07-2010 08:26 AM
kabcpapc
03-24-2006 01:20 AM
Quick Reply: difficult to fill gas tank
