Another "Truck died, no start" thread...
Old 04-21-2011, 11:55 PM
Brown Falcon's Avatar
Brown Falcon
Brown Falcon is offline
IPR plug, got it... Hard to see down in there.
It looked like the little "keepers" are broken off of it, so the plug won't snap on. Maybe duct tape will work... lol
Old 04-21-2011, 11:56 PM
Talyn's Avatar
Talyn
Talyn is offline
that not good. they are metal though, they shoudln't snap off.
Old 04-22-2011, 10:27 AM
mq1shooter's Avatar
mq1shooter
mq1shooter is offline
My 95 had the plastic keepers, and one was broken, and would work loose....thus act like a miss or die....I got a replacement kit from Ebay with the metal bale / snap wire and I like it better....
Old 04-22-2011, 11:17 AM
Action4478's Avatar
Action4478
Action4478 is offline
I have read the injector wiring has the same clip ..
Old 04-22-2011, 11:31 AM
Talyn's Avatar
Talyn
Talyn is offline
I read that also rick. I'll check later today.
Old 04-22-2011, 12:13 PM
Brown Falcon
Thanks again for the help guys. Just glad it wasn't something expensive...
Old 04-22-2011, 12:14 PM
Talyn's Avatar
Talyn
Talyn is offline
Motor is too hot to tell on the IPR plug vs Injector plug.
Old 04-22-2011, 12:52 PM
pjwoolw's Avatar
pjwoolw
pjwoolw is offline
The pigtail seems to run about thirty bucks from IH. The harness is about sixty five from Ed. Part numbers are in the part number sticky.
Old 04-22-2011, 03:30 PM
mq1shooter's Avatar
mq1shooter
I search the other forum's and the Injector Clip and IPR clip was mentioned as the same and pic's where posted...but I wasn't convinced that they were?...but I didn't have them in my hand.....Ford Diesel 6.0 & 7.3 IPR REGULATOR WIRE REPAIR KIT | eBay
Old 04-22-2011, 03:36 PM
Brown Falcon
Thanks for the info.
I can't remember now if the clips on the plug were broken or the nubs on the IPR were broken...
Probably would have to buy a new IPR if the nubs are broken.
Old 04-22-2011, 04:19 PM
mq1shooter's Avatar
mq1shooter
IDK? but if memory serves me - seems I lose a little each day - the bail wire snaps over the connector/coil....think the plastic snaps are no longer in play........IIRC.
Old 04-22-2011, 07:45 PM
Talyn's Avatar
Talyn
Talyn is offline
an injector plug will work and snap in just like the injector does.
same plug on the injectors.
  #28
Old 04-23-2011, 11:22 AM
Brown Falcon
Cool, i'll have to get a new connector for it...
willeo6709
09-05-2009 01:48 AM
ggirten
47
04-25-2009 01:50 PM
emxmagnum
03-05-2007 09:55 PM
sandiayfz
02-23-2007 11:12 PM
79man
11-29-2006 01:07 PM
Quick Reply: Another "Truck died, no start" thread...
