Changed drivebelt & air filter now poor low end - Ford Truck Enthusiasts Forums
Old 04-20-2011, 11:30 PM
Domestic_Nuwbee's Avatar
Domestic_Nuwbee Domestic_Nuwbee is offline
Domestic_Nuwbee is starting off with a positive reputation.
I just changed my drivebelt and air filter the other day and now my low end sucks big time! shes not sputtering, nor bucking or making any noise on hard acceleration.....just seems sluggish on the low end now.
I had a crappy Fram air filter that I changed to K&N on a stock longtube-box w/ factory ram. And replaced the drivebelt with a Dayco. Belt is AC length as it is bypassed with a idler pulley. And the tension sits within range, jus slightly to the left from middle point.
My truck was running awesome until i changed the above. Anyone help me out with this one?
its a 90 F250, 302 HO with ignition upgrade and 3 degree timing bump.
Thanks,
Old 04-20-2011, 11:52 PM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
I think the issue is unrelated to the service work you performed. As a test pull out the K&N filter then drive the truck for a SHORT distance, if the performance improves you have a problem with that filter. Otherwise there is something else wrong, bad karma/pure coincidence. I would not buy a lottery ticket for the next few days....
Old 04-21-2011, 12:12 AM
Quote:
How did I know you'd be the first to respond?! Im going to totally ignore that you said there's something else wrong! Hahaha. So the chances of a "defective" filter are likely and I'm the sucker who ended up with it? Will try that out and see what happens. Thank RLA
Old 04-21-2011, 12:22 AM
joshofalltrades joshofalltrades is offline
joshofalltrades has a good reputation on FTE.joshofalltrades has a good reputation on FTE.
the other common mistake is to have left a hose or wire harness unplugged as you were working on it. go back and check all your connections
Old 04-21-2011, 12:24 AM
rla2005's Avatar
Misery loves company. I thought I was the only one born under a dark cloud.
Old 04-21-2011, 12:25 AM
rla2005's Avatar
Quote:
Good point
Old 04-21-2011, 07:28 PM
Good point
Nothing else gets touched changing the drive belt other than the tensioner.... only thing connected to the air box is the breather off the valve cover.
Old 04-21-2011, 09:01 PM
Iwork on too many cars, and many of them want you to unplug the maf or other sensors to get the air box open
Old 04-22-2011, 12:34 AM
I hear what your saying, but my motor is SD. Thanks bro
Old 04-22-2011, 02:04 AM
redmondjp's Avatar
redmondjp redmondjp is offline
redmondjp is gaining momentum as a positive member of FTE.redmondjp is gaining momentum as a positive member of FTE.
Could it be that the old drive belt was slipping so you weren't seeing the full HP load of the accessories, and now the new belt is grippier (george bush would be proud) so something like the alternator is now loading down the engine more?
Just another hypothesis . . .
Knock Knock, who's there? (no joke here) jlr1073 1987 - 1996 F150 & Larger F-Series Trucks 3 02-22-2010 11:04 AM
GatorBack Belt gabe823 2004 - 2008 F150 3 08-25-2008 02:31 PM
help: temp gauge fluctuating pretty rapidly bad thermostat? R6elmo Ranger & B-Series 7 03-23-2004 11:35 AM
2 different drive-belt tensioners?? aeomholt Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 0 01-17-2004 06:16 PM
Belt noise 91Van 1987 - 1996 F150 & Larger F-Series Trucks 29 10-13-2003 10:36 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
