Removing manifolds. - Ford Truck Enthusiasts Forums
Removing manifolds.
Old 04-20-2011, 11:11 PM
BigBlue92 BigBlue92 is offline
BigBlue92 is starting off with a positive reputation.
Removing manifolds.
I'm working on taking off my exhaust manifolds and replacing them with headers. The only problem is I'm havin trouble gettin the old bolts loose. I've been spraying them with penetrating fluid everyday for a week before I even attemped to turn em loose. I'm also worried about breaking the bolts and reallly digging myself a hole. Any tips or ideas?
Old 04-20-2011, 11:21 PM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Heat is your best friend if the penetrating fluid comes up short. What are you using?
Old 04-21-2011, 03:11 AM
TexasGuy001 TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
If your truck is higher mileage and has never had the manifolds off, I suggest leaving it alone. You don't want broken bolts in the heads. Its a 50/50 chance you will break one or more off in the head. In my opinion its not worth it. They only way I would consider headers is if they were going on a fresh motor or the heads were already off to be reworked.
Old 04-21-2011, 08:06 AM
I'm just using some liquid wrench penetrating fluid.
Old 04-21-2011, 09:12 AM
1lilredwagon's Avatar
1lilredwagon 1lilredwagon is offline
1lilredwagon is starting off with a positive reputation.
Use an air chisel and put force directly on the head of the bolt as if you were trying to push it into the cylinder head. Make sure you use a blunt tool when doing this. I got 13 out with my fingers this way two snapped and the other took some heat. Using a right angle drill you can drill and tap the bolts easily do all the work from the wheel well with the plastic liner removed.
Old 04-21-2011, 09:13 AM
White Max's Avatar
White Max White Max is offline
White Max has a good reputation on FTE.White Max has a good reputation on FTE.
Get yourself some AeroKroil, heat them up, tap the bolt heads with a hammer, then use an impact wrench to get them out. Even doing all of that, you can plan on breaking at least one of the bolts.
Old 04-21-2011, 09:19 AM
BRay09's Avatar
BRay09 BRay09 is offline
BRay09 is gaining momentum as a positive member of FTE.
Also, pb blaster is the best penetrating oil out there! I agree with leaving them alone if they are not cracked or broken. But with the plastic wheel wells out and you can get an impact on there then that's easily the best option. Hopefully you don't have real rusty motor because if you do then those bolts are more than likely soft and thin And you will break them.
Old 04-21-2011, 09:43 AM
IowanStraight6's Avatar
IowanStraight6 IowanStraight6 is offline
IowanStraight6 is starting off with a positive reputation.
pb blaster and squirt and tap squirt and tap did this on the exaust end tube and the bolts came right out of the ends of the heads also work em back and forth tight then loose goodluck
Old 04-21-2011, 10:13 AM
timbersteel's Avatar
timbersteel timbersteel is offline
timbersteel has a good reputation on FTE.timbersteel has a good reputation on FTE.
Another good suggestion perhaps..
Use the "Freeze-Off" nut&bolt loosening agent. I have had luck heating the bolts up and then spraying some of the "freeze-off" on them to help expand and contrct them, breaking them free. As White Max said about AeroKroil, try that as well!! It's expensive, but it does work. Keep sparying them and then drive for awhile. Let it cool down and spray them again. This heat and cool cycle along with some penetrating lubricant will be your friend in safely removing the bolts.
Best of luck!
Old 04-21-2011, 12:37 PM
bigteal bigteal is offline
bigteal is starting off with a positive reputation.
I had 107000 on mine when I did the headers. I drove the truck for a while, and while it still hot, I put pressure on them to TIGHTEN them and then loosen them. No need for any PB blaster, they all came out easy, except the last one. I knew would break anyway due to corrosion.
What is with the broken exhaust manifold bolts on these fords? fishgeek 1997 - 2003 F150 1 11-01-2011 01:21 AM
Exhaust Manifold Removal hartmark FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 25 10-05-2010 08:22 AM
Recommended torque for 223 manifold? erinaldi 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 10-16-2008 09:38 PM
460 Exhaust manifold bolts coming loose fasthauler Exhaust Systems 0 06-23-2008 12:34 AM
Exhaust Manifold Torque Specs fusioncom 1967 - 1972 F-100 & Larger F-Series Trucks 8 06-30-2006 09:52 AM
Tags
96, exhaust, f150, manifolds, removing, stock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
