Stupid sandblaster keeps clogging - Ford Truck Enthusiasts Forums
Old 04-20-2011, 10:37 PM
Doc's Avatar
Doc Doc is offline
Doc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud of
Okay I have borrowed my buddies Central Pneumatic (harbor freight brand) sandblaster. It's one of those pot blasters. I've tried fine dry play sand and the black course media. No matter what I do, this thing clogs. Before I throw this thing over the hill, can somebody tell me what I might be doing wrong. The media is absolutely dry. I even took the ceramic orifice completely out of the hose and it still clogs.
Old 04-20-2011, 10:42 PM
mechmagcn's Avatar
mechmagcn mechmagcn is online now
Diesel Junky
mechmagcn has a very good reputation on FTE.mechmagcn has a very good reputation on FTE.mechmagcn has a very good reputation on FTE.
Try not opening the sand valve at the bottom of the pot all the way, I found this helped on mine.
Old 04-20-2011, 10:46 PM
arrowheadfred's Avatar
arrowheadfred arrowheadfred is offline
arrowheadfred has a good reputation on FTE.arrowheadfred has a good reputation on FTE.
clog
Hey doc you can't just pour these items in and blast. You need to get a fine screen and put it in the top of the pot and it will stop all the big stuff from passing and it should work better. Take a welding rod and clean out the tip also.
Old 04-20-2011, 10:47 PM
sdetweil's Avatar
sdetweil sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
Quote:
I'm with Jeff.. close the media valve, open the air valve, and slowly open the media valve til you get a reliable flow.. I had a heck of a time with pebbles in the play sand.. after I screened all that out it went much better.
the media valve was never open all the way.
Sam
Old 04-20-2011, 10:50 PM
yep
This is also true !!!!!!!
Old 04-20-2011, 10:57 PM
Doc's Avatar
Doc Doc is offline
Thanks guys. That makes perfect sense about the media valve at the bottom of the tank. What about the valve at the top of the tank after the split with the air line? Should it be wide open?
Old 04-20-2011, 11:03 PM
sdetweil's Avatar
Quote:
I always have it wide open..as much air in to the tank as possible
Sam
Old 04-20-2011, 11:55 PM
tinman52's Avatar
tinman52 tinman52 is offline
Welder User
tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.
Also make sure your air supply is dry. Any moisture in the lines will make blasting miserable.
The valve you are referring to normally stays open...if you get a clog of wet sand, try closing it momentarily. This will force all of the air thru the tank....will usually blow the clog out.
Old 04-21-2011, 12:27 AM
way2fast1's Avatar
way2fast1 way2fast1 is offline
way2fast1 is starting off with a positive reputation.
Sam
I could never open the sand valve more than half when i blasted my trailer.
They are kinda finicky good luck!
Old 04-21-2011, 01:34 AM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
Another tip is to use construction sand, not play sand or cheap stuff like that. You get it from a building materials store, where they sell masonry materials. Ask for #70 silica sand. It's a fine enough grit that won't pit bad, won't clog as easy, but is still course enough to clean up your metal good. As mentioned, your sand has to be absolutely clean and dry, as well as your air, too. You typically need a really big compressor with a dryer to make a sand blaster work well.
Old 04-21-2011, 06:36 AM
Walston's Avatar
Walston Walston is online now
Walston has a great reputation on FTE.Walston has a great reputation on FTE.Walston has a great reputation on FTE.Walston has a great reputation on FTE.Walston has a great reputation on FTE.
I use mine with the air valve open and I slowly open the "sand" valve until I have a good blasting stream. The one on the bottom is usually about 40 or 50% open, more than that will plug.
You MUST have a water knock out or it will plug all the time. I actually have two, one at the compressor and one on the blaster. It you don't take the water out you will plug often.
Using sand is dangerous because fine silica in the lungs can kill you. If you use sand instead of something like black beauty you better at least do it outside and have a very good positive pressure air supplying respirator. I would get black beauty and not risk your health.
Old 04-21-2011, 07:16 AM
hellfirejim's Avatar
hellfirejim hellfirejim is offline
hellfirejim is starting off with a positive reputation.
Where can you buy black beauty and what do you ask for?
thanks
jim
Old 04-21-2011, 07:17 AM
49willard 49willard is offline
49willard has a great reputation on FTE.49willard has a great reputation on FTE.49willard has a great reputation on FTE.49willard has a great reputation on FTE.
Doc, You received good advice here. My original sandblaster was a Tip that I bought at Hershey about 30 years ago, the same basic design as your unit. I experienced the same issues but managed to get it to work better although it was always problematic. I installed a piping cross (a 4 way like a 3 way tee but with 4) at the bottom to help clean out if it did plug.
A few years later I ran across a used Lindsey pressure pot, also at Hershey, and having used one before, I bought it for the right money and sold the Tip. The secret is in the mixing valve at the bottom. I have never had it plug and I do mean never! Lindsey (a New Hampshire company) sold out about 10 years ago but one of the real big guys in commercial sandbasters (I can't remember the name) bought up the company with that design and last I knew they were still available but at a high price (Like $1000+). I paid about 1/10 of that almost 30 years ago. The Linsdsey's were always green in color but the color changed to red after the company was sold.
Edit: It was Marco that bought Lindsey. Northern has the Marco unit like my Lindsey for a big WOW! $1700
Old 04-21-2011, 07:48 AM
sdetweil's Avatar
Quote:
thanks
jim
Black BeautyŽ Abrasive (Boiler slag, Coal slag) from READE
Coal Slag Blasting Abrasive — 25 Lbs. | Blasting Media | Northern Tool + Equipment
and I agree with the comments about the dryer and water trap.. the HF unit has a water trap
Sam
Old 04-21-2011, 09:02 AM
Doc's Avatar
Doc Doc is offline
Heck yeah it's some good advice. And I appreciate it. I had my sand valve wide open. And take a guess who's gonna pick up a couple of those water traps today. I actually remember having one in my hand when I bought my compressor and somehow laid it down before I got to the checkout counter.
Sandblaster suggestions egg collector Paint & Bodywork 8 01-11-2014 12:43 AM
what temperature is best for sandblasting? mrstephs Paint & Bodywork 7 07-29-2008 02:03 PM
Problem with Sandblasting 1984F15016 Garage & Workshop 17 06-21-2005 11:55 AM
Need Sandblasting Tips sancochojoe Paint & Bodywork 9 01-29-2004 09:40 PM
how much would it cost to sand blast a frame? hazardousdrew 1961 - 1966 F-100 & Larger F-Series Trucks 2 12-11-2003 11:31 PM
Tags
300, 80, clogging, f100, freight, gallon, harbor, lindsay, prevent, quincy, sandblaster, screen, t5, tank, tip, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
