Stupid sandblaster keeps clogging
Old 04-21-2011, 01:22 PM
sdetweil's Avatar
sdetweil
sdetweil is offline
Originally Posted by 49willard
I am very pleased with the purchase about 3 years ago of a 7 1/2 hp IR 2 stage compressor. I previously used a Smith Gordan conversion setup for a Model A or B short block. It compresses on #2 and #3 and fires on #1 and #4. Since the Model A is about 40 hp, I figured that I had about a 20 hp gas air compressor. The IR is about equal to the old Smith Gordan setup for air delivery.
For continuous running of a sandblaster, I find that the 7 1/2 hp 2 stage IR is the right size.
hey man.. no braggin!.. that compressor is THE machine.. I sized my compressor wiring in case I should be lucky enough to come up with one.. missed one last summer from a closing shop for $500 by about 15 minutes.
sam
  #32
Old 04-21-2011, 01:37 PM
fast_st's Avatar
fast_st
fast_st is offline
I picked up a really nice Quincy QR25 monster 5hp 240 volt, 22 amps 240 running close to 100 startup amps. Running a TIP sandblaster it stays around 75-80 psi. Compressor is huge, some 600 plus pounds, motor weighs 110 pounds. Its definately not a magic 5hp like the portable 110v compressors. Mine came from a screen printing shop that upgraded to two screw compressors.
  #33
Old 04-21-2011, 04:10 PM
49willard's Avatar
49willard
49willard is offline
Sam,
I made do for years with cobbled up setups. For about 20 years I had 3 and 4 hp sears tied together and mounted on top of a free 80 gallon horizontal air tank. One of the original small sears tanks rusted through so I dropped that compressor pump and motor down and direct mounted it to the pad on top of the 80 gallon tank. One day when I was running a die grinder (cutting out the cab floor on Willard) it seemed like I had to wait too long to build pressure back up. I went out into the outer shop and saw a compressor belt on the floor. I thought no problem one of the units just through a belt. I went to reinstall the belt and noticed that the large compressor pulley was missing. I thought, well still no problem. Then I noticed that the crankshaft had sheared off with a stub end still in the compressor pulley. That was the aha moment that I said to myself, now I am finally going to get a good compressor. That resulted in the 7 1/2 hp 2 stage IR.
  #34
Old 04-21-2011, 04:31 PM
53 Effie's Avatar
53 Effie
53 Effie is offline
Originally Posted by Mountaindoc
I've got that upright 60 gallon Ingersoll Rand compressor that Tractor Supply sells. I think it's 11.3 CFM. I know, I probably need one even bigger than that. I'm gonna have to stop and let it catch up quite a bit. Which brings up another point--I probably should shut that sand valve off completely during rest periods so that a ton of sand doesn't trickle down and clog the pipe. I'm realizing I made just about every mistake possible yesterday. LOL. But hey, maybe somebody else will read this and learn something too.
Pay attention to your compressor's duty cycle. I didn't and it wasn't very long before I was replacing a head gasket on a fairly new compressor.
As for using silica sand as a media, especially outdoors, you have to be concerned with the health of everyone down wind as well as yourself. I use aluminum oxide in my cabinet blaster and have a portable soda blaster that I plan to use when it is time for doing sheet metal.
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Rick
  #35
Old 04-21-2011, 05:05 PM
sdetweil's Avatar
sdetweil
sdetweil is offline
Sam,
I bow to you..
can u run the air hose to my house/shop?
Sam
  #36
Old 04-21-2011, 08:23 PM
49willard's Avatar
49willard
Sam,
The pressure drop from Maine to Texas might be a bit too much!
  #37
Old 04-21-2011, 08:42 PM
Jeff and Nicolle's Avatar
Jeff and Nicolle
Jeff and Nicolle is offline
Nobody mentioned it but I buy the Black Beauty media at Menards. Its black anyway...? like 8 bucks/ 50 lb bag I think thats the price...
  #38
Old 04-21-2011, 08:57 PM
havi's Avatar
havi
havi is offline
I'll have the Roast Duck
Sam,
It'd be worth trying!
  #39
Old 04-21-2011, 11:09 PM
sdetweil's Avatar
sdetweil
sdetweil is offline
Sam,
man.. such excuses.. I'd PAY you for the Maine air displaced..
oh well.. I'll just have to keep looking for a closer solution!.
again I bow to you
Sam
  #40
Old 04-22-2011, 07:26 AM
tardster's Avatar
tardster
tardster is offline
Thanks guys this is a great thread, too bad I needed it last summer when I had the truck tore apart and was using mine on the frame. Boy that was a PITA only being able to blast for a few minutes at a time. I have the HF sand blaster and was having the same issue with it. Now I will try it again when it comes time to start prepping the body for paint. Yay something positive for me today...
  #41
Old 03-25-2013, 08:55 AM
Alan'sExpy's Avatar
Alan'sExpy
Alan'sExpy is offline
Thanks!!
Thank you guys for posting this thread! I know it's an old thread but I'm glad it was here and I found it because it just saved me!
I had the same issues and was about to totally give up on it, but following the advice here got it working!
I also found another tip on a different forum - It talked about the short pipe below the sand valve on the bottom of the tank. It's screwed far into the manifold cutting off the flow. If you take off the big black hose that leads to your nozzle and look down in the manifold you will see that pipe (nipple). The tip is to drill it out so as to open the passage up.
I did this and the other tips in this thread and got it blasting.
Thanks guys for posting to this thread! - it saved me!
Here's the link to the other tip I was talking about:
H1FORUM.COM :: View topic - Harbor Freight sandblaster vs Texas Blaster
"after the close nipples are installed firmly on the manifold - maybe even installed on the bottom of the tank - although I didn't do mine in this way - run successively larger drill bits down the manifold from the nipple where the heavy black blasting hose attaches at the bottom of the tank. The problem here is that the close nipple from the bottom of the tank to the center of the manifold sticks way into the manifold - it cuts off the passage by at least 50% which causes a ton of jams. Start with a bit that fits inside the end nipple (again the one where the black hose attaches). After you've cut off the protruding end of the center nipple (protruding on the inside of the unit) then move up 3 or 4 drill sizes (I use a standard drill index) to open up the ID if the end nipple. Go slow through all of this because the drill bit wants to catch the ragged end of the middle close nipple - I broke a bit in this process, but got it out easily. Again, this is the MOST IMPORTANT modification."
  #42
Old 03-25-2013, 06:34 PM
55f100rod's Avatar
55f100rod
55f100rod is offline
These guys are right must have absolute dry media and air supply as well as adequate air supply. I cant really help with your set up because I sandblast and powder coat for a living. So needless to say my John Deere diesel 185cfm air compressor and 6.0 cubic foot (500lb media capacity hopper) set up is much bigger than yours and ive never actually used a that particular unit. but in theory they mostly work the same except some are pressure fed where as mine is gravity fed. I still only have my sand valve opened less than half way. A lot of people think you need all this sand or other media to blast the clean everything off and with rust a lot of times thats the case, but with paint or other coatings the sand is actually used to break the coating down and the air pressure from the compressor is whats doing the work to actually lift the coating off and remove it.
  #43
Old 03-25-2013, 09:04 PM
havi's Avatar
havi
havi is offline
I've been eyeballing the dustless DB150 as of late. Very expensive! But in my neck of the woods, nobody else is doing it, and it could be a business opportunity.
rechinca
19
07-26-2017 02:31 AM
Jrj4379
10-12-2016 11:59 PM
DesertZuki
12-21-2015 10:59 PM
7636074460
03-26-2014 08:18 PM
egg collector
Paint & Bodywork
01-10-2014 11:43 PM
Quick Reply: Stupid sandblaster keeps clogging
