Stupid sandblaster keeps clogging - Page 2 - Ford Truck Enthusiasts Forums
Old 04-21-2011, 09:19 AM
Walston's Avatar
Walston Walston is online now
Walston has a great reputation on FTE.Walston has a great reputation on FTE.Walston has a great reputation on FTE.Walston has a great reputation on FTE.Walston has a great reputation on FTE.
Quote:
Originally Posted by hellfirejim View Post
Where can you buy black beauty and what do you ask for?
thanks
jim
If you do a google search for "Black Beauty Blast Media" it shows many places to buy it.
Old 04-21-2011, 09:39 AM
hellfirejim's Avatar
hellfirejim hellfirejim is offline
hellfirejim is starting off with a positive reputation.
Thanks all.
jim
Old 04-21-2011, 10:00 AM
fast_st fast_st is offline
fast_st is starting off with a positive reputation.
Yeah, when I blast I'll blow a fan over the air tank to cool it down a little and leave the drain open just a whisker so the shaking of the compressor will coax all the water out. I've also shimmed my compressor (horizontal) to pitch it 2 inches toward the drain. One trap on the compressor output and another cyclone dryer on the blaster. Dry is key, I was thinking of using a coil of copper pipe in a bucket of water to extract even a little more. Tap water temp being 55 degrees, that'd work great on an 80 degree day.
Old 04-21-2011, 10:24 AM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
Just to be clear, none of this stuff is healthy. Dust and debris from Black Beauty-type materials are just as deadly as silica. Perhaps you noticed where it said it is a coal slag product? I'm assuming you eastern guys have heard of 'Black Lung?' Bottom line is, be careful when using any of these products and use the proper safety equipment. Eyes, lungs, and body. You don't have to be afraid of these products and materials, (and I'll include paint for this discussion, as well) but you should treat them with respect.
Old 04-21-2011, 10:30 AM
sdetweil's Avatar
sdetweil sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
Quote:
Originally Posted by 52 Merc View Post
... You don't have to be afraid of these products and materials, (and I'll include paint for this discussion, as well) but you should treat them with respect.
cause they will NOT respect YOU!
Sam
Old 04-21-2011, 10:44 AM
dongc1's Avatar
dongc1 dongc1 is offline
dongc1 is starting off with a positive reputation.
I have the same pot as the one you are using. I use Black Diamond in it. I get it at Tractor Supply. It works better than sand and less dust.I have 2 water separators on the pot. After I installed them, I don't have problems with clogging anymore. The bottom valve is about half open and the top valve is wide open. Use the largest nozzle you can use and still maintain 75-80 PSI at the pot. I have run many, many bags of Black diamond and the pot works great.
Old 04-21-2011, 10:45 AM
Doc's Avatar
Doc Doc is offline
Doc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud of
You're definitely right. Trust me, I deal with black lung in one way or other every day. I take care of a lot of guys with silicosis too around here (usually highwall drill operators). As a matter of fact, I've got one hooked up to oxygen and an IV right now.
Most of the men in my family look like this guy at the end of the day.
Old 04-21-2011, 11:02 AM
Doc's Avatar
Doc Doc is offline
Quote:
When you say you have 2 water separators on the pot, are you meaning you have 2 mounted in sequence on the incoming line before it splits? I'm just glad to hear that there is hope for this thing and the operator is the problem (I'm starting to recognize a trend there ).
Old 04-21-2011, 11:07 AM
Yeah, I salvaged a used air mask from the fire department, attached it to an oilless compressor and use that for fresh air however wrong that might be. Keeps the dust outta my nose.
Old 04-21-2011, 11:09 AM
firstrider's Avatar
firstrider firstrider is offline
firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.
Havre blasted tons of sand and parts . 3 main points .
1 . Media MUST be dry !!!
2 . If media will not pass thru window screen , it will not pass thru blaster.
3. Air /sand ratio is most important .
Get sand from a ridge by the rail tracks .Pure white sugar sand . Spread out to dry , sift over a large container with a frame work made out of metal window screen , store inside and blast away when needed .Plenty of sand here in Fla.
Old 04-21-2011, 11:36 AM
cj06's Avatar
cj06 cj06 is offline
cj06 is gaining momentum as a positive member of FTE.
how much CFM is your compressor putting out ? to small of a compressor and you can only open the valve just a little ! i have used lots of silica sand from Home Depot and had good results on equipment , but always wore a good mask , not those cheap dust masks that you get 5 or 8 for a few bucks !
Old 04-21-2011, 11:50 AM
Doc's Avatar
Doc Doc is offline
I've got that upright 60 gallon Ingersoll Rand compressor that Tractor Supply sells. I think it's 11.3 CFM. I know, I probably need one even bigger than that. I'm gonna have to stop and let it catch up quite a bit. Which brings up another point--I probably should shut that sand valve off completely during rest periods so that a ton of sand doesn't trickle down and clog the pipe. I'm realizing I made just about every mistake possible yesterday. LOL. But hey, maybe somebody else will read this and learn something too.
  #28
Old 04-21-2011, 11:57 AM
sdetweil's Avatar
once I get the media valve set, I don't fiddle with it. its hard enough the set once!.
you can shut the air valve into the tank.,.
Sam
  #29
Old 04-21-2011, 12:18 PM
dongc1's Avatar
Yes, I have 2 separators, in series, in the incoming air line. I never have to screen the Black Diamond. Dump it in and GO. Leave the valve on the bottom alone when you shut down, just shut the air off. It will take a few seconds to bleed down and you will spray out some sand, but it is much easier than messing with everything. When you start back up, it will take a few seconds for the sand to start flowing again.
  #30
Old 04-21-2011, 01:57 PM
49willard 49willard is offline
49willard has a great reputation on FTE.49willard has a great reputation on FTE.49willard has a great reputation on FTE.49willard has a great reputation on FTE.
I am very pleased with the purchase about 3 years ago of a 7 1/2 hp IR 2 stage compressor. I previously used a Smith Gordan conversion setup for a Model A or B short block. It compresses on #2 and #3 and fires on #1 and #4. Since the Model A is about 40 hp, I figured that I had about a 20 hp gas air compressor. The IR is about equal to the old Smith Gordan setup for air delivery.
For continuous running of a sandblaster, I find that the 7 1/2 hp 2 stage IR is the right size.
Egr clogged again after 300 miles! Jrj4379 6.0L Power Stroke Diesel 15 10-13-2016 12:59 AM
Sandblaster suggestions egg collector Paint & Bodywork 8 01-11-2014 12:43 AM
Sandblasting axles soon, have some questions. RabidJade General Automotive Discussion 18 11-17-2013 09:12 AM
oil cooler ? Living Proof 6.0L Power Stroke Diesel 5 04-30-2013 09:07 PM
Sand blasted parts-how to prep? SkiDooHauler Garage & Workshop 9 05-25-2004 11:29 PM
Tags
300, 80, clogging, f100, freight, gallon, harbor, lindsay, prevent, quincy, sandblaster, screen, t5, tank, tip, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
