1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
problem starting F250, 2004 6.0L
Old 04-20-2011, 08:40 PM
kodiak_f250's Avatar
kodiak_f250
kodiak_f250 is offline
I have a 2004 6.0L V8 32V DDI OHV Turbo Diesel.
Today for the first time since buying it about 6 months ago, when I turned over the key, the engine wouldn't start. The low-fuel light is on, but there is still plenty of fuel, I think it turns on sooner, because the needle is not in the red.
Anyways, the starter sounds normal at first and then it gives off this swish sound (high winding noise, then it stops), after trying it for a 6th time, it eventually started. Then I drove it home, turned it off and also wouldn't start at 1st try, it started on the 2nd try.
What do you guys think this problem is ?
Thanks!
xxdbkxx
10-24-2013 12:41 PM
omatty
11-23-2011 09:51 AM
hurley1718
04-26-2011 11:21 PM
dbmstr124
06-20-2008 02:36 PM
Quick Reply: problem starting F250, 2004 6.0L
