problem starting F250, 2004 6.0L - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 04-20-2011, 08:40 PM
kodiak_f250's Avatar
kodiak_f250 kodiak_f250 is offline
kodiak_f250 is starting off with a positive reputation.
I have a 2004 6.0L V8 32V DDI OHV Turbo Diesel.
Today for the first time since buying it about 6 months ago, when I turned over the key, the engine wouldn't start. The low-fuel light is on, but there is still plenty of fuel, I think it turns on sooner, because the needle is not in the red.
Anyways, the starter sounds normal at first and then it gives off this swish sound (high winding noise, then it stops), after trying it for a 6th time, it eventually started. Then I drove it home, turned it off and also wouldn't start at 1st try, it started on the 2nd try.
What do you guys think this problem is ?
Thanks!
2004 F-350 6.0L diesel won't start xxdbkxx 1999 to 2016 Super Duty 14 10-24-2013 12:41 PM
2008 Escape Sputtering When Trying to Start neubauer6 Escape & Escape Hybrid 0 03-12-2012 08:40 AM
2004 explorer 4.0 problems omatty Explorer, Sport Trac, Mountaineer & Aviator 1 11-23-2011 09:51 AM
2004 Explorer XLT Cranks but wont turn over...HELP hurley1718 Explorer, Sport Trac, Mountaineer & Aviator 5 04-26-2011 11:21 PM
HELP!!! My truck is down dbmstr124 6.0L Power Stroke Diesel 11 06-20-2008 02:36 PM
Tags
2004, 60, diesel, duty, f250, f2502004, f550, ford, ignition, problem, problems, starting, super, trouble, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
