Help solve my transmission fluid leak!! - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 04-20-2011, 09:15 PM
clickjd clickjd is offline
clickjd is starting off with a positive reputation.
We've had a SMALL transmission fluid leak in our 2002 Escape since about Thanksgiving... Our mechanic is retired with a nice shop behind his house and he's replaced and tightened various things. It started with a leaky rear seal which he replaced, but we noticed it leaking right after that. The seal was now dry, so on the recommendation of the dealership he replaced some kind of axel and another seal (sorry, not a car expert here). It kept leaking. Just a spot about the size of a silver dollar under that cylinder-shaped thing near the front. He then replaced the dip stick o-ring, and for a few days we thought the problem was gone. But when I took the car on a longer drive it was leaking again. I think it might be leaking less than it was. We don't drive it much, just around town usually, but it seems to have gone from a constant drip to an intermittant drip.
Actually, the CarMax papers we got with it (we bought it in April 2010) indicated they're replaced a seal, too.
Our mechanic can't think of what it could be. He says the transmission seems fine, and it runs great. When he puts it on his lift he can't see anything dripping from anywhere. But driving it we'll occasionally smell transmission fluid smoking as it drips onto hot car parts, and see that annoying little drip hanging from the cylinder, and would love to get to the bottom of this.
Any ideas? THANKS!!!!
Ford-O-Matic Slip Yoke Seal Rusty_S Clutch, Transmission, Differential, Axle & Transfer Case 1 09-15-2015 10:54 PM
2001 Epedition Transmission major leak issue Bootlegger's Deluxe 1997 - 2003 F150 3 06-10-2015 12:01 PM
Puzzler of a transmission issue PhauxNub Excursion - King of SUVs 33 06-03-2015 02:35 PM
tranny leaking very much, now cant get it to do it again. cptaylor 1987 - 1996 F150 & Larger F-Series Trucks 3 06-29-2014 07:19 PM
2002 Escape: Small transmission fluid drip clickjd Escape & Escape Hybrid 2 03-10-2011 08:49 AM
Tags
1996, 2002, 40, dripping, escape, f150, fluid, ford, leak, leaking, mazda, ranger, seal, tranaxle, transmission, tribute
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
