1995 F150 Air Conditioner - Ford Truck Enthusiasts Forums
Old 04-20-2011, 09:00 PM
mtntop1's Avatar
mtntop1 mtntop1 is offline
mtntop1 is starting off with a positive reputation.
Here's my problem and it has been doing this for 10 years.After driving around with the air on and then park and shut the engine off for an hour and restart the air it blows very warm air for about five minutes then cools off.I replaced the compressor three times,flushed the system,change the dryer,vacuumed the sys down,changed the pressure on the dryer switch twice , change the pressure switch on the compressor twice and it still does it.Could there be something in the vacum system causing this,like opening the heater door then closing it.I am at a lose.
Old 04-20-2011, 09:55 PM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Did you change the Orifice tube?
No the cold/hot door is controled by a cable and not vacuum.
Old 04-20-2011, 11:15 PM
mtntop1's Avatar
Changed it three times.
Old 04-20-2011, 11:48 PM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
What are the low and high pressures when this happens? What is the vent temperature as well as ambient? Sounds like heat soak to me if the charge and pressures are in range.
Is the heat deflector material on the blower/evaporator case in place?
Old 04-21-2011, 09:16 AM
mtntop1's Avatar
Low side pressure 30psi, high side 240 psi ambient temp 90 to 95 degrees.Heat shield in place on case, vent temp at 40 degrees.
Old 04-21-2011, 11:36 AM
rla2005's Avatar
Are those values listed when the system is working properly or after the heat soak?
Old 04-21-2011, 05:31 PM
mtntop1's Avatar
The values are when it is working properly.
Old 04-21-2011, 07:02 PM
rla2005's Avatar
I am not trying to be an *** here, but have you checked the pressures and vent temps. when you say the vents are blowing warm air for 5 minutes after sitting for an hour or so? That should tell you if the compressor is actually turning on and working in the designed pressure range.
Old 04-21-2011, 07:43 PM
mtntop1's Avatar
I go to work in the morning with the air on.When I get off five hours later ( I work part time ) start the truck turn on the air it blows warm.When the air starts to work the vent temp are cold,the same goes if the engine is off for only an hour or less.When I start the engine and drive off right away it only takes about a minute to start cooling.Also the compressor is engaged while it is blowing warm air.I ahve checked just about everything even the vacuum hoses.Like I said previously I changed the compressor three times and also the dryer.,pressure switches,flush system.This has been going on for ten years.I was thinking that some how the heater door is opening for some reason.
You are not being an ***,you are just trying to help me.
Old 04-21-2011, 07:48 PM
SideWinder4.9l's Avatar
SideWinder4.9l SideWinder4.9l is offline
SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.
Mine is like that....Takes it a lil while, then it gets COLD....Personally, I would imagine some air in the lines would make it take longer to get the cold air pumping....Use a 4 way screwdriver, and bump the ball valve on the low side....If there is some air caught in there, it'll release it....Technically, its illegal, because it will also allow the refrigrant out too...
-Wes
Old 04-21-2011, 08:08 PM
mtntop1's Avatar
I'll try anything at this point.
Old 04-21-2011, 08:11 PM
The valve will allow refrigerant and air both out...Push it in for a sec or two....See how that works....The refrigerant will start spraying out when the air bubble is gone...Just make sure not to breathe the air near the valve, because it will take you out FAST....And don't touch the refrigerant....
-Wes
Old 04-21-2011, 08:50 PM
mtntop1's Avatar
Ok thanks.
a/c help needed. 6ohdslbilder 1968-2013 Full Size Vans 8 07-16-2015 08:07 AM
A/C Repair Question bbacon Excursion - King of SUVs 18 08-10-2014 07:50 PM
AC Problem during acceleration after complete replacement ag-ford-4x4 Cooling, Heating, Ventilation & A/C 16 07-02-2014 09:02 AM
03 f250 6.0 no power to a/c clutch crewsd Cooling, Heating, Ventilation & A/C 2 06-30-2011 10:08 AM
Help: 2004 Navigator 4wd air dryer/compressor lines bullfrog 1997-2006 Expedition & Navigator 1 02-16-2011 09:37 PM
Tags
1995, 4x4, air, airconditioner, conditioner, conputer, control, f150, f150air, f53, filter, ford, forum, panel, truck, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
