2003 Expedition won't shift out of park - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 04-20-2011, 07:19 PM
chadwj chadwj is offline
chadwj is starting off with a positive reputation.
Picked the kids up from school got in the car and couldn't shift from park. From the research I've done (including searching this forum) it could be a fuse. We ended up walking home. I am trying to find out how to override the shift interlock but can't find the instructions and of course the owners manual is in the truck stuck at the school. Does anyone have the instructions so I can get the truck home?
Old 04-20-2011, 08:14 PM
Okay, I finally found the info I needed and got the SUV home. I have posted it below if anyone else needs it down the road.
AUTOMATIC TRANSMISSION OPERATION
Brake-shift interlock
This vehicle is equipped with a park/brake-shift interlock feature that
prevents the gearshift lever from being moved from P (Park) when the
ignition is in the ON position unless brake pedal is depressed.
If you cannot move the gearshift lever out of P (Park) with ignition in
the ON position and the brake pedal depressed, or when the ignition is
in the OFF position, it is possible that a fuse has blown or the vehicle’s
brakelamps are not operating properly. Refer to Fuses and relays in the
Roadside emergencies chapter.
If the fuse is not blown, perform the following procedure:
1. Apply the parking brake, turn the ignition to OFF, then remove the
key.
2. Push the tilt steering lever down and tilt the steering column all the
way up.
3. Locate the round access plug on
the underside of the steering
column cover.
4. Remove the access plug using a flat-head screwdriver, then insert your
finger and pull the override button toward you. With the button pulled
toward you, apply the brake pedal and shift the transmission into N
(Neutral).
5. Reinstall the access plug cover, start the vehicle and release the
parking brake.
Do not drive your vehicle until you verify that the brakelamps
are working.
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Turn key forward from LOCK to unlock shift lever. Place lever in N. Start engine. Shift into D or R. If you go back to P, you will have to start over.
Check fuse F5 in the in-cabin fuse box. If okay, check the brake pedal position switch.
E4OD Shifting Hard, please help!!! oldtruck36 1987 - 1996 F150 & Larger F-Series Trucks 71 01-02-2017 01:55 PM
Cold truck won't shift out of park while running. hasteranger 6.0L Power Stroke Diesel 4 12-20-2016 07:41 PM
Moody e4od Rather be Strokin 1987 - 1996 F150 & Larger F-Series Trucks 8 04-15-2015 11:03 PM
Tailgate trim removal Feardeere7 1973 - 1979 F-100 & Larger F-Series Trucks 6 03-20-2013 09:41 PM
gear shift from park littlewad Ranger & B-Series 5 06-11-2012 01:31 PM
Tags
1997, 2002, 2003, 2005, 2007, expedition, explorer, ford, key, lincoln, navigator, park, shift, turned, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
