1973 F250 headers for 460?? - Ford Truck Enthusiasts Forums
Old 04-20-2011, 11:34 AM
Ford4X4ingboy's Avatar
Ford4X4ingboy Ford4X4ingboy is offline
Ford4X4ingboy is starting off with a positive reputation.
I found a pretty decent truck for sale. Its a 1973 Ford F250 4 speed with a 460. And I was thinking about buying it, But i was hoping to put on headers and straight pipe. And i couldnt find any headers that fit a 1973 F250 with a 460. :/ Any one know where i could find some?
Old 04-20-2011, 11:45 AM
bucks77ford's Avatar
bucks77ford bucks77ford is offline
bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.
4x4 or 2wd?
Old 04-20-2011, 12:47 PM
montana_highboy montana_highboy is offline
montana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud of
Old 04-20-2011, 01:21 PM
Quote:
Originally Posted by bucks77ford View Post
4x4 or 2wd?
It is a 4X4
Old 04-20-2011, 03:07 PM
Quote:
Originally Posted by montana_highboy View Post
Quote:
Originally Posted by Ford4X4ingboy View Post
It is a 4X4
L&L is about the only place that I've found who supplies them for that application. I'd suggest going with 1967-79 Full Size Truck/bronco - 429 & 460 Swap Kits - Headers
When I bought mine 3 years ago, they were cheaper through them than directly from L&L and they are the same header. If you do go with Broncograveyard, call them first because it's possible they won't have any in stock since they get theirs from L&L. They are an expensive header but well built and about the only header I could fine. I run chassis exit and they fit just fine without any modification. The fenderwell exits only require a little triming of the inner fender.
Old 04-20-2011, 05:53 PM
co425's Avatar
co425 co425 is offline
co425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to all
+1 on the l&l I have chasis exits and they are the finest headers I have owned yet. Worth the money so far.
Old 05-02-2011, 12:45 AM
Alright, what about a 1979 F250 4X4 with a 390. I cant find headers for that either!
Old 09-04-2011, 02:51 AM
73f250highboy's Avatar
73f250highboy 73f250highboy is offline
73f250highboy has a good reputation on FTE.73f250highboy has a good reputation on FTE.
The 390 never came in a 4x4 but it is the exact same motor as the 360 other then the stroke. Anyways ive been researching and i was wondering (for the people who have bought l&l headers from bronco graveyard) Do they come with the collectors, bolts, reducers, and gaskets? On l&ls website it says they do but i cant seem to figure out if they do from bronco graveyard
Old 09-04-2011, 07:36 AM
co425's Avatar
Yes they do come with the collectors, bolts and gaskets. But if I were you I would spend the money on copper gaskets, and stage 8 locking fasteners. They are a little spendy. I bought mine from summit and the price wasn't terrible. I think the gaskets were around $30.00 and the bolts were around $45.00.
Old 09-04-2011, 07:39 AM
co425's Avatar
Oh. One more thing with the stage 8's you have to file the locks a little to make them fit right up to the bolts. But other then that easy install. Also account for the thick flanges before you order the bolts.
Old 09-04-2011, 07:45 AM
grinnergetter's Avatar
grinnergetter grinnergetter is offline
grinnergetter has a good reputation on FTE.grinnergetter has a good reputation on FTE.
Quote:
x2.....I used 1 1/4 stage 8's. I couldn't find the length anywhere else but I was in a hurry.
I placed the order from Jeff's and they shipped from L&L.
Old 09-04-2011, 12:11 PM
Oh and on l&ls website it says 1/2 think flange
Looking for headers 1972fordhighboy2 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 09-06-2016 07:39 PM
Header fitment andrew's64 1973 - 1979 F-100 & Larger F-Series Trucks 2 02-10-2016 03:59 PM
Need help on some 460 headers ss27gogeta 1973 - 1979 F-100 & Larger F-Series Trucks 6 05-12-2014 12:36 AM
1973 Ford F250 with 460 swap 2WD. Header Question. Kudofo 1973 - 1979 F-100 & Larger F-Series Trucks 11 08-18-2011 04:51 PM
Cant find headers! tikkakoski 1973 - 1979 F-100 & Larger F-Series Trucks 17 04-19-2010 04:00 AM
Tags
1966, 1973, 460, 4x4, 74, conversion, exhaust, f100, f250, ford, fordtruck, header, headers, highboy, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
