Exhaust manifold removal... DONE, back on truck (Pics!) - Ford Truck Enthusiasts Forums
Old 04-20-2011, 07:08 AM
CPUNeck's Avatar
CPUNeck CPUNeck is offline
CPUNeck has a very good reputation on FTE.CPUNeck has a very good reputation on FTE.CPUNeck has a very good reputation on FTE.CPUNeck has a very good reputation on FTE.
Thumbs up Exhaust manifold removal... DONE, back on truck (Pics!)
Ok, so the Brine here in TN is "eating" my truck, so I decided to remove the manafolds, up pipes, and collector to have them ceramic coated. Well I obviously don't posses the magic others must have, who easily removed their manifolds.
On the passenger side, #5 cyl, there is one bolt that won't budge. I'm out of gas right now, so the blue wrench was down. I've modified two sockets and managed to hammer a 12mm socket on that bolt, still to no avail.
Now I've got room on the passenger side, but on the DRIVER's side... ganged up with crap. Seems the engine is positioned slightly more to the passenger side, and I don't even see how I'm going to get a socket and extension on the drivers side.
PB was employed 1st, and through out. How have you guys gotten the manifolds off???
Old 04-20-2011, 07:25 AM
riverrat41's Avatar
riverrat41 riverrat41 is offline
riverrat41 is a splendid one to beholdriverrat41 is a splendid one to beholdriverrat41 is a splendid one to beholdriverrat41 is a splendid one to beholdriverrat41 is a splendid one to beholdriverrat41 is a splendid one to behold
I have read the stories about the manifolds being a PITA.I have a little soot around mine and have been waiting for it to get really bad before tackling this.No real help from me,just wanting to be in the loop on responses.
Old 04-20-2011, 09:23 AM
Rose Clifford's Avatar
Rose Clifford Rose Clifford is offline
Rose Clifford has a great reputation on FTE.Rose Clifford has a great reputation on FTE.Rose Clifford has a great reputation on FTE.Rose Clifford has a great reputation on FTE.
heat the bolts up.....that a possibility? works like charm when its possible
Old 04-20-2011, 09:48 AM
onelionhunter onelionhunter is offline
onelionhunter has a very good reputation on FTE.onelionhunter has a very good reputation on FTE.onelionhunter has a very good reputation on FTE.
Inner fender
If I remember correctly, many take the tire off and the inner fender liner, then everythig is exposed and easier to deal with.
Old 04-20-2011, 09:49 AM
mueckster's Avatar
mueckster mueckster is offline
aka Redneck Wrencher
mueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputation
Can you hit the head of the bolt with a hammer to shock the threads? It sometimes loosens them up without having to resort to heat. Worth a shot. I work on heavy equipment and trucks that are exposed to coal ash dust. The effects of it are caustic and dealing with stuck parts are an everday occurrence.
Old 04-20-2011, 06:43 PM
tdpower's Avatar
tdpower tdpower is offline
tdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to behold
Good luck CPU! I have looked at those before and thought to myself I sure hope I don't ever have to take those off.
Old 04-20-2011, 06:58 PM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
Get that torch refilled.
"Thermal persuasion" works the best for stubborn parts.
Old 04-20-2011, 07:38 PM
big poppa's Avatar
big poppa big poppa is offline
big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.
I dreaded the though of removal too, especially my passenger side, salt, grime, moisture. Good luck bud...Wished I could be more help except spray, spray, overnite, spray.
Old 04-20-2011, 08:11 PM
CPUNeck's Avatar
Moral support may be what the doctor ordered In regards to "hitting the bolt", I worked it hard, and put it up wet with my 4lb persuader.
Here is what I'm up against.
<table style="width: auto;"><tbody><tr><td></td></tr><tr><td style="font-family: arial,sans-serif; font-size: 11px; text-align: right;">From Exhaust Manifolds</td></tr></tbody></table>
Concerning the drivers side, I'd be scared to death to deploy the blue wrench!
https://picasaweb.google.com/CasperC...austManifolds#
Old 04-20-2011, 08:31 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Worst case, cut the head off the bolt so you can get the manifold off. That should give you enough room to get the torch in there to heat things up and leave you plenty of stud to grab a hold of. The extra clearance would make it easier to stick a heat shield in there.
If you've got all the other bolts removed, I'd stick them back in and snug them up. You don't want any torque on the bolt from the manifold hanging there making it more difficult.
Also remember that many penetrating fluids are flammable so be careful before you light the torch up and start applying heat.
Old 04-20-2011, 08:56 PM
<TABLE style="WIDTH: auto"><TBODY><TR><TD></TD></TR><TR><TD style="TEXT-ALIGN: right; FONT-FAMILY: arial,sans-serif; FONT-SIZE: 11px">From Exhaust Manifolds</TD></TR></TBODY></TABLE>
https://picasaweb.google.com/lh/phot...eat=directlink
I have a set of extractor sockets that can best be described as an easy-out on the inside. Spiral cut teeth that grab onto stripped bolt heads like in that picture. And they DO NOT let go. One of the best purchases that I have ever made. Makes childs play of stripped out nuts, bolts, allen head CV bolts, everything.
Might be worth your investment to get the job done.
Matco tools part number MBX13.
Saws & Cutting Tools, Bolt Extractors | Matco Tools Online Tool Catalog
Old 04-20-2011, 09:09 PM
CPUNeck's Avatar
Well being the tool mister I am, believe there is a drawer in the box that kit would fit nicely in. Have to make sure I have enough beans though.
After seeing the carnage the bolts left behind in the manifolds, may have to purchase new ones .
Old 04-20-2011, 09:10 PM
BigAlsPSD's Avatar
BigAlsPSD BigAlsPSD is offline
BigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud of
Budget then look into IRWIN tools versions, available at Oreilly and even Lowes. http://www.oreillyauto.com/site/c/de...0673&ppt=C0099
Old 04-20-2011, 09:26 PM
Nick 99's Avatar
Nick 99 Nick 99 is offline
Nick 99 is gaining momentum as a positive member of FTE.
Try mixing up some acetone and ATF 50/50, apply liberally after heating bolt, let soak till cool, give it a turn.
Old 04-20-2011, 10:06 PM
bluescrew's Avatar
bluescrew bluescrew is offline
bluescrew is gaining momentum as a positive member of FTE.
this is exactly why i caved, and paid to get this fixed!
Swapping the transmission in a 2010 Expedition marcusjb 2007 - 2014 Expedition & Navigator 2 06-13-2016 06:11 PM
07 F250 Pass Exhaust Manifold BlackLabel 1999 to 2016 Super Duty 1 08-07-2015 10:12 PM
Replacing passenger side exhaust manifold gaskets on a 2010 3V 5.4. twigsV10 2007 - 2014 Expedition & Navigator 2 07-30-2015 12:45 AM
EBPV delete turned into PITA 97powersmoke 1994.5 - 1997 7.3L Power Stroke Diesel 19 05-16-2015 07:46 AM
Drivers side rear turn signal / brake light issues Scoop531 1973 - 1979 F-100 & Larger F-Series Trucks 3 02-17-2014 05:58 AM
Tags
42, 73, 99, cyl, early, escape, exhaust, f150, ford, inline, manifold, manifolds, pics, removal, remove, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
