Exhaust manifold removal... DONE, back on truck (Pics!) - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 04-26-2011, 09:58 PM
PaulDH PaulDH is offline
PaulDH is gaining momentum as a positive member of FTE.
Got any more info on the motor home rail chassis PS pump. Will it fasten directly to the existing Super Duty PS pump bracket? Does it use a better high pressure PS hose connection to the pump?
I agree the PS pumps on the Super Duty are a piece of junk. Besides the funky O-ring sealed plastic pump housing, the high pressure hose connection to the pump is a joke. The high pressure power steering hose blows free of the PS pump due to lousy design.
  #47
Old 04-26-2011, 10:06 PM
bulla's Avatar
bulla bulla is offline
bulla has a very good reputation on FTE.bulla has a very good reputation on FTE.bulla has a very good reputation on FTE.
So basically the bolt was stuck in the monifold and not the threads themselves? I was told back when I first got my truck to check for leaks and I remember being able to get a lil bit on all the bolts. But that was with a long 3/8 ratchet, I didn't know what a torque wrench was back then! Lol
  #48
Old 04-26-2011, 10:08 PM
bulla's Avatar
Guess what I was getting at was we don't have that corrosion issue round here unless you get down on the gulf!
  #49
Old 04-27-2011, 06:32 AM
CPUNeck's Avatar
CPUNeck CPUNeck is offline
CPUNeck has a very good reputation on FTE.CPUNeck has a very good reputation on FTE.CPUNeck has a very good reputation on FTE.CPUNeck has a very good reputation on FTE.
Quote:
You got it. I'm from GA, and for 9+ years my truck didn't rust. Stationed here in TN for 2 years, and on a quiet night I can hear my truck rusting.
  #50
Old 04-27-2011, 10:31 AM
SkySkiJason's Avatar
SkySkiJason SkySkiJason is offline
SkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant future
The bolts stick in the manifolds because the threads create a space in the smooth bore of the manifold. RUST expands steel 4x and LOCKS them in place. The torque on bolts to heads is only 38ft lbs IIRC - and no 'space' for rust - so they seem to come out pretty easily. I am quite certain you went ahead and replaced all the bolts, but since ya didn't mention it...
Rust sucks! I think coating the manifolds will help mitigate this problem and wonder if it would be worth the effort to coat the part of the bolt that goes thru manifold for good measure. I lathered mine up with high-temp anti-sieze, but know it won't last forever in that environment.
I'd say you need some resurfacing - but we can only hope its the manifolds that are out of spec... Don't use gaskets unless you like this job, since they will eventually 'wear out' for the same reason the donuts in stock up-pipes fail. Metal-to-metal should last indefinitely.
Btw, I'll be passing thru in a couple weeks - hoping to hook up with y'all on the way by! Dunno if you've seen the new Toy Hauler TT behind the Excursion yet, but we sure do like it! Setting up the CF, etc in the garage for the ultimate on-the-road filtration system as well as extra clean WVO storage and pump/hose for easy refueling in-route!
  #51
Old 04-27-2011, 10:33 AM
rat49f6's Avatar
rat49f6 rat49f6 is offline
rat49f6 is a splendid one to beholdrat49f6 is a splendid one to beholdrat49f6 is a splendid one to beholdrat49f6 is a splendid one to beholdrat49f6 is a splendid one to beholdrat49f6 is a splendid one to behold
Please tell is more about this motor home PS pump
  #52
Old 04-27-2011, 10:37 AM
Oh yeah, are you using Turbo X coating?? Or some other product?
I have an extra set of manifolds I'm gonna blast and coat. Now that you've got some practice, maybe I'll just drop the X off at your place and pick it up when yer done?
It really sux ya live so far away these days, I'd have been there for you if I could.......
  #53
Old 04-27-2011, 07:21 PM
CPUNeck's Avatar
Jason, call when you're in the area (my txt is hit or miss)... I've amassed some new garage toys since your last visit.
Ok, I'll do more research for F53 chassis power steering pump. Nothing concrete right now EXCEPT it doesn't have the d&^% O-ring mounting/seal configuration. More to follow.
  #54
Old 05-01-2011, 07:08 PM
CPUNeck's Avatar
So, I'm winning... here is what the doctor ordered to remove the rusted bolt on the passenger side manifold.
That's a 20-Ton press applying about 18, with regular PB Blaster shots. Didn't phase it.
<table style="width:auto;"><tbody><tr><td></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From Exhaust Manifolds</td></tr></tbody></table>
Maybe a relief hole drilled into the bolt will do it.
Nope, still couldn't press it out. Ok I'll redeploy the blue wrench, along with a buddy.
Well with ~20min of heat, burning off the rust, it still wouldn't budge. Last trick, poured some liquid CO2 down the relief hole in the bolt... THEN it pressed out!
My album, https://picasaweb.google.com/CasperC...eat=directlink, also has pics of how bad the rust really was on this manifold. Much worse than the D/S for some reason. Had to deploy the needle scaler prior to blasting, but the finished product is good. Just an update, till paint, weather here is BAD.
  #55
Old 05-02-2011, 10:37 AM
Holy crap!
Uh, where do ya get liquid CO2??
  #56
Old 05-02-2011, 04:02 PM
Bonanza35 Bonanza35 is offline
Bonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to behold
Quote:
Originally Posted by SkySkiJason View Post
Holy crap!
My thought exactly. I have the gas in cyclinder but no liquid. Dose the welding supply have this? Chet
  #57
Old 05-03-2011, 11:11 AM
CPUNeck's Avatar
Ok, I'll let you guys in on my secret... How about a can of dust off, up-side DOWN
  #58
Old 05-03-2011, 12:43 PM
bulla's Avatar
I was thinking that but didn't know if you had a bigger supply of it or something. So are you having the manifolds re surfaced? And are you using a gasket?
  #59
Old 05-03-2011, 12:49 PM
Quote:
Damn, that is too easy. When I grow up I wanna be as smart as you are!!!
  #60
Old 05-04-2011, 06:49 AM
CPUNeck's Avatar
Yep, necessity is the mother of invention. You should've seen my nephew's face, he learned a lot . We both were concerned the press was going to torpedo my manifold across the shop.
I'm going to use a gasket... it's an experiment, as alot of what I'm doing is, until I get my up-pipes. It will probably about a year before I install them.
Testing:
Grill paint on the up-pipes and down pipe.
Techline "Black Satin" header coating (manifolds, compressor housing on turbo)
Permatex® Ceramic Extreme Brake Parts Lubricant (as rust inhibitor for bolt shoulders at manifold, and all exhaust connections)
Caliper paint (5-way plenum, and CAC tubes)
We'll see how they all perform.
Swapping the transmission in a 2010 Expedition marcusjb 2007 - 2014 Expedition & Navigator 2 06-13-2016 06:11 PM
07 F250 Pass Exhaust Manifold BlackLabel 1999 to 2016 Super Duty 1 08-07-2015 10:12 PM
Replacing passenger side exhaust manifold gaskets on a 2010 3V 5.4. twigsV10 2007 - 2014 Expedition & Navigator 2 07-30-2015 12:45 AM
EBPV delete turned into PITA 97powersmoke 1994.5 - 1997 7.3L Power Stroke Diesel 19 05-16-2015 07:46 AM
Drivers side rear turn signal / brake light issues Scoop531 1973 - 1979 F-100 & Larger F-Series Trucks 3 02-17-2014 05:58 AM
Tags
42, 73, 99, cyl, early, escape, exhaust, f150, ford, inline, manifold, manifolds, pics, removal, remove, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
