Exhaust manifold removal... DONE, back on truck (Pics!) - Page 2 - Ford Truck Enthusiasts Forums
Old 04-21-2011, 03:04 AM
Fat Diesel's Avatar
Fat Diesel Fat Diesel is offline
Fat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud of
Quote:
Originally Posted by Kwikkordead View Post
I have a set of extractor sockets that can best be described as an easy-out on the inside. Spiral cut teeth that grab onto stripped bolt heads like in that picture. And they DO NOT let go. One of the best purchases that I have ever made. Makes childs play of stripped out nuts, bolts, allen head CV bolts, everything.
Might be worth your investment to get the job done.
Matco tools part number MBX13.
Saws & Cutting Tools, Bolt Extractors | Matco Tools Online Tool Catalog
I have those same ones as well as this big one. Since I bought the set I haven't met their match.
http://lh3.googleusercontent.com/pub...mviRrQZZXOe1Ro
Old 04-21-2011, 03:15 AM
twags6's Avatar
twags6 twags6 is offline
PAA Member #7 and FTE
twags6 has a very good reputation on FTE.twags6 has a very good reputation on FTE.twags6 has a very good reputation on FTE.twags6 has a very good reputation on FTE.
My dad has one of those laying in his tool box. I always wondered what it was.
Old 04-21-2011, 12:14 PM
dknouse's Avatar
dknouse dknouse is offline
dknouse is starting off with a positive reputation.
Quote:
How do these get the bolt out? I can't see how it would fit on the bolt head.
Old 04-21-2011, 12:41 PM
Fat Diesel's Avatar
It's a stud remover. If the head of the bolt fits in then that'd work too. The twisting of the knurled piece binds the stud and allows you to turn it, or break it off deeper...
Old 04-21-2011, 04:42 PM
papadelogan's Avatar
papadelogan papadelogan is offline
Snowboard season cometh..
papadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to behold
Technically that's a stud remover/installer but like many things, the flexibility of the tool is directly proportional to the flexibility of the mind using it.
Old 04-22-2011, 03:45 PM
jwill8957's Avatar
jwill8957 jwill8957 is offline
jwill8957 is starting off with a positive reputation.
I cut the heads off pulled the manifold off and took the studs out
Old 04-22-2011, 07:56 PM
Nick 99's Avatar
Nick 99 Nick 99 is offline
Nick 99 is gaining momentum as a positive member of FTE.
Awesome, now what are going to do to fix the original problem?
Old 04-22-2011, 10:59 PM
bluescrew's Avatar
bluescrew bluescrew is offline
bluescrew is gaining momentum as a positive member of FTE.
machine the manifold and use a steel gasket?
Old 04-22-2011, 11:17 PM
Nick 99's Avatar
Did it have a gasket originally? I don't think Ford recommends exhaust manifold gaskets, because it doesn't transfer heat as well.
Old 04-23-2011, 12:17 AM
4wydnr 4wydnr is offline
4wydnr is starting off with a positive reputation.
Quote:
That's what I did too. The bolts came out of the head with just a pair of vise grips. The problem was they had rusted into the manifolds. But with the manifold on the bench you can either heat them and hit them with a punch or air hammer. If that doesn't work they might have to be drilled out.
I took mine to the local napa and had them resurface the manifold so hopefully it will bolt up flush and not leak with out a gasket.
Old 04-23-2011, 06:43 PM
CPUNeck's Avatar
CPUNeck CPUNeck is offline
CPUNeck has a very good reputation on FTE.CPUNeck has a very good reputation on FTE.CPUNeck has a very good reputation on FTE.CPUNeck has a very good reputation on FTE.
Well the blue wrench is still down, and here is what my truck though about those bolt extractors. It laughed.
<table style="width: auto;"><tbody><tr><td></td></tr><tr><td style="font-family: arial,sans-serif; font-size: 11px; text-align: right;">From Exhaust Manifolds</td></tr></tbody></table><table style="width: auto;"><tbody><tr><td></td></tr><tr><td style="font-family: arial,sans-serif; font-size: 11px; text-align: right;">From Exhaust Manifolds
<table style="width: auto;"><tbody><tr><td></td></tr><tr><td style="font-family: arial,sans-serif; font-size: 11px; text-align: right;">From Exhaust Manifolds</td></tr></tbody></table><table style="width: auto;"><tbody><tr><td></td></tr><tr><td style="font-family: arial,sans-serif; font-size: 11px; text-align: right;">From Exhaust Manifolds</td></tr></tbody></table>
Old 04-23-2011, 08:47 PM
tdpower's Avatar
tdpower tdpower is offline
tdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to behold
It might be the quality of the extractor. I have bought some cheap drill bits for tapping. They didn't last very long. IDK but good luck again brother. Maybe you just need a BFH..
  #28
Old 04-23-2011, 09:24 PM
JOHN2001's Avatar
JOHN2001 JOHN2001 is offline
JOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to behold
I will be doing this job as soon as my wife and I close on our first house soon I have leaks at all 4 points of the manifold to block, blown up-pipes and a van turbo Im gonna put on. Im Gonna get the ceramic coated up-pipes from Clay. I can tell from this thread its gonna be a PITA. I have a couple questions. If I can find a large belt sander and lay the manifold flat on it wouldnt that get it close enough to being flat? What can I do to make the job eaiser next time if I ned to take the manifold off, would never seize work or is that too much heat for it to work? I also want to sand blast the manifolds and paint them too, does anyone sell ceramic coating paint I can rattle can on there? Thanks
  #29
Old 04-23-2011, 09:46 PM
beanhead6D5's Avatar
beanhead6D5 beanhead6D5 is offline
beanhead6D5 is a name known to allbeanhead6D5 is a name known to allbeanhead6D5 is a name known to allbeanhead6D5 is a name known to allbeanhead6D5 is a name known to allbeanhead6D5 is a name known to all
Quote:
Originally Posted by CPUNeck View Post
Well being the tool mister I am, believe there is a drawer in the box that kit would fit nicely in. Have to make sure I have enough beans though.
After seeing the carnage the bolts left behind in the manifolds, may have to purchase new ones .
If you bugger one or both manifolds up I have a set in the shop I can send to you.
How you been Casper??? its been a while.
  #30
Old 04-23-2011, 09:53 PM
EDIT: Double post
Swapping the transmission in a 2010 Expedition marcusjb 2007 - 2014 Expedition & Navigator 2 06-13-2016 07:11 PM
V10 Exhaust Stud removal Journey marcot11 Excursion - King of SUVs 15 06-11-2016 04:24 PM
07 F250 Pass Exhaust Manifold BlackLabel 1999 to 2016 Super Duty 1 08-07-2015 11:12 PM
Replacing passenger side exhaust manifold gaskets on a 2010 3V 5.4. twigsV10 2007 - 2014 Expedition & Navigator 2 07-30-2015 01:45 AM
EBPV delete turned into PITA 97powersmoke 1994.5 - 1997 7.3L Power Stroke Diesel 19 05-16-2015 08:46 AM
Tags
42, 73, 99, cyl, early, escape, exhaust, f150, ford, inline, manifold, manifolds, pics, removal, remove, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
