Clutch cable broke?
Clutch cable broke?
Ok so here goes with my bad luck streak on day 2. Tonight while driving home from a buddies house i turned the corner and was shifting into 2nd gear. As soon as i pushed the clutch in i heard a bang, the pedal hit the floor and stayed there, and a little plastic piece hit my leg. Turns out the clutch cable has gone and broke itself or atleast the plastic connector thing. Thats my guess anyway. Any input as to what you think happened and also how to fix it would be great! 1996 f150 inline 6
Well you have a hydraulic clutch so there is no cable.
If you look up under the dash you will see the clutch pedal, it and the brake pedal pivot on one horizontal bar, follow that bar over towards the center on the cab and you will see a part that mates up with a rod that goes into a black plastic switch with a connector on it, that is the master cylinder and neutral safety switch.
Take a look under there and see what is broken, or take a picture and maybe someone on here can tell you what you broke.
Bleeding a Concentric Hydraulic Clutch Set-up .: Articles Good article here. Make sure you bench bleed the master cyl before you fit it.
on
ive never bleed anything before cause im new to the whole fixing my own truck thing. so a little more details than that or pictures? i dont even know where to start. any simple instructions on how to do this would be great! Ive gotten as far as to remove the old master cylinder from the fire wall. the hose and everything are still attached. The new cylinder has a little pin and o-ring type thing and i dont know if i need these. I assume the pin is for the hose to hold it in place. the oring a gasket? as for bleeding. i have no idea. Im going to go out on a whim and say fill the reservoir put the lid back on and pump the pedal?
It is best to get all the air out of the new cyl before you bolt it in. You can do this by filling it with fluid and slowly pushing the piston in, then put your finger over the fluid outlet before releasing the piston so that air is not drawn in. Do this several times until only fluid cones out with no air. Then bolt the new cyl in position (connect pipe) and connect to the clutch pedal.
Now pump the pedal and see how good the clutch is. If there is still air in it you can then open the bleed screw down at the transmission end of the hydraulic line and get a helper to slowly push the pedal to bleed any air out. Make sure you keep the resevoir topped up at all times.
Or if you have 2 helpers you can put everything on and get a rubber vacuum line that can connect to the bleeder on the slave. Use a clean clear container and put the brake fluid in it. Insert the vacuum line in the container and have one person continue to fill the reservoir while the other pumps the pedal. Do this until the air bubbles quit coming out.
