Clutch cable broke? - Ford Truck Enthusiasts Forums
Clutch cable broke?
Old 04-19-2011, 11:57 PM
MFogarty1996's Avatar
MFogarty1996 MFogarty1996 is offline
MFogarty1996 is starting off with a positive reputation.
Clutch cable broke?
Ok so here goes with my bad luck streak on day 2. Tonight while driving home from a buddies house i turned the corner and was shifting into 2nd gear. As soon as i pushed the clutch in i heard a bang, the pedal hit the floor and stayed there, and a little plastic piece hit my leg. Turns out the clutch cable has gone and broke itself or atleast the plastic connector thing. Thats my guess anyway. Any input as to what you think happened and also how to fix it would be great! 1996 f150 inline 6
Old 04-20-2011, 12:26 AM
Bovaloe's Avatar
Bovaloe Bovaloe is offline
Bovaloe is starting off with a positive reputation.
Well you have a hydraulic clutch so there is no cable.
If you look up under the dash you will see the clutch pedal, it and the brake pedal pivot on one horizontal bar, follow that bar over towards the center on the cab and you will see a part that mates up with a rod that goes into a black plastic switch with a connector on it, that is the master cylinder and neutral safety switch.
Take a look under there and see what is broken, or take a picture and maybe someone on here can tell you what you broke.
Old 04-20-2011, 09:35 AM
Ok, so i found what you said to look for and i took pictures.
Now incase you havnt realized im not very good with trucks or parts, im tryin to learn. So idk what this is or how to fix it. explain? Thank you!
Old 04-20-2011, 10:05 AM
jas88's Avatar
jas88 jas88 is offline
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
You need a new clutch master cylinder.
Old 04-20-2011, 11:44 AM
how does one go about fixing this? It seems pretty simple the replacing part undo the old one disconnect the fluid line put new in and re connect the line. Is that about it? and i know id have the bleed the line after, how do i do that?
Old 04-20-2011, 11:48 AM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
Bleeding a Concentric Hydraulic Clutch Set-up .: Articles Good article here. Make sure you bench bleed the master cyl before you fit it.
Old 04-20-2011, 01:48 PM
jas88's Avatar
The hydraulic line is held in your master cylinder with a roll pin - knocking it out is a little tricky because it is so small. Other than that, it's pretty straightforward IMO.
Old 04-20-2011, 05:42 PM
Would you recommend a novice tackle this, or would you say have someone at a shop do it untill i learn for sure how do this type of job?
Old 04-20-2011, 06:25 PM
Bovaloe's Avatar
Only one way to learn.... Do it yourself
Old 04-20-2011, 07:54 PM
Do i have to bench bleed the system before putting it on, or can i just bleed the system after i put the new one on?
Old 04-20-2011, 08:56 PM
jas88's Avatar
On yours you can just open the bleeder on the slave cylinder (at the trans) and gravity bleed it.
Old 04-20-2011, 09:13 PM
ive never bleed anything before cause im new to the whole fixing my own truck thing. so a little more details than that or pictures? i dont even know where to start. any simple instructions on how to do this would be great! Ive gotten as far as to remove the old master cylinder from the fire wall. the hose and everything are still attached. The new cylinder has a little pin and o-ring type thing and i dont know if i need these. I assume the pin is for the hose to hold it in place. the oring a gasket? as for bleeding. i have no idea. Im going to go out on a whim and say fill the reservoir put the lid back on and pump the pedal?
Old 04-21-2011, 07:52 AM
Quote:
You need to disconnect the line from the old cyl and connect it to the new one with the new pin and seal.
It is best to get all the air out of the new cyl before you bolt it in. You can do this by filling it with fluid and slowly pushing the piston in, then put your finger over the fluid outlet before releasing the piston so that air is not drawn in. Do this several times until only fluid cones out with no air. Then bolt the new cyl in position (connect pipe) and connect to the clutch pedal.
Now pump the pedal and see how good the clutch is. If there is still air in it you can then open the bleed screw down at the transmission end of the hydraulic line and get a helper to slowly push the pedal to bleed any air out. Make sure you keep the resevoir topped up at all times.
Old 04-21-2011, 08:39 AM
thanks im going to give it a try now so i have most of the day to do it. If needed, and i hope it doesn't weather calls for rain later D:
Old 04-21-2011, 09:29 AM
BRay09's Avatar
BRay09 BRay09 is offline
BRay09 is gaining momentum as a positive member of FTE.
Or if you have 2 helpers you can put everything on and get a rubber vacuum line that can connect to the bleeder on the slave. Use a clean clear container and put the brake fluid in it. Insert the vacuum line in the container and have one person continue to fill the reservoir while the other pumps the pedal. Do this until the air bubbles quit coming out.
1996 F-250 hydraulic clutch cub102 1987 - 1996 F150 & Larger F-Series Trucks 3 04-16-2015 09:06 PM
Clutch Return Spring sonny1965 1961 - 1966 F-100 & Larger F-Series Trucks 2 06-08-2014 06:33 AM
ZF6 Clutch Issues... RacerLT250R 1999 - 2003 7.3L Power Stroke Diesel 7 07-05-2012 10:46 AM
two things ChristopherN 1987 - 1996 F150 & Larger F-Series Trucks 15 06-09-2011 09:10 AM
Clutch rod to clutch pedal plastic retainer Eaglefixer Ranger & B-Series 2 11-30-2009 01:24 PM
Tags
1993, 1999, 200, 2003, 2007, cable, clutch, conversion, f150, f250, f350, ford, ranger, replacement, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
