1973 F250 Heater fan squeaky! - Ford Truck Enthusiasts Forums
Old 04-19-2011, 09:37 PM
torpedo51's Avatar
torpedo51 torpedo51 is offline
torpedo51 is starting off with a positive reputation.
When the fan is spinning, it squeaks like bloody murder. It spins at the correct speed, but sounds terrible.
I've never taken the blower unit apart - whats going to be the problem? The fan motor, or the fan itself?
Old 04-19-2011, 10:33 PM
Rickpwjr Rickpwjr is offline
Rickpwjr is starting off with a positive reputation.
My 75 F250 was doing the same thing. My truck had not been started for a long time, like 8 years, when I got it. The heater fan would just howl when I switched it on so loud you couldn't talk over it. Sometimes intrmitent and sometimes non-stop. Then once in a while it would be quiet for 10 minutes and then suddenly start screeching so loud I jumped an almost changed lanes. I tried squirting some oil into the squirrel cage hoping it would hit something. No luck. As a last resort I went into the engine compartment and sprayed the casing of the fan motor protruding from the firewall with WD40. I soaked it with oil. The next day when I turned the fan on it chirped for 10 seconds and has not made a noise since. Its been about 8 months and is still working fine.
Old 04-19-2011, 11:20 PM
torpedo51's Avatar
Yeah - thats exactly my problem! I'll try hosing it down with WD40 like you said.
I like a cheap fix!
Thanks!
T
Old 04-20-2011, 06:58 AM
Mustangtoby2001 Mustangtoby2001 is offline
Mustangtoby2001 is starting off with a positive reputation.
sounds like the bearing in the motor are going bad, somtimes the wd40 will cure them by breaking up the old hardened grease in there, other times it will only wash out what is there and make it worse. The heavier oil you use the better off you will be. Worse case, get a new heater motor, not to bad to install. Good luck w/ the wd40, hopefully you won't have to do any more than that.
Old 04-20-2011, 09:43 AM
ford4604bbl ford4604bbl is offline
ford4604bbl is starting off with a positive reputation.
Don't use WD40 it has salt in it....The name stands for Water Dryer formula # 40 it was never intended as a lubricator just go buy some Rem Oil it works much better and does what it is intended to do Lubricate and you can get it in spray or liquid form.
Old 04-26-2011, 05:27 PM
torpedo51's Avatar
Steve,
A comparision of WD-40 and Rem Oil:
"WD" in WD-40 stands for "Water Displacement", not "Water Dryer". The functioning ingredient in WD-40 is Mineral Oil - which is a non-volatile and light weight lubricant. When the propellant and degreasing components evaporate, the remaining Mineral Oil displaces air and water making it beneficial for resisting corrosion.
Whether or not there are salts present in the WD-40 (or Rem Oil) solution is of no consequence as long as there is no precipitation or residue that inhibit the product's intended purpose. Salts don't "dry" water, but that would be a positive effect if they did.
Rem Oil and WD-40 are nearly identical in composition. The primary difference is that Rem Oil contains Teflon instead of Mineral Oil. Teflon and Mineral Oil are both corrosion inhibitors and lubricants. They are both petroleum distillates.
While there are plenty of applications where Teflon is superior to WD-40, its subjective to declare that Rem Oil is "much better" for this application. Also, declaring that WD-40 was "never intended as a lubricant" is irrelevant - the product IS a lubricant.
Remington's Marketing Dept has you fooled. Rem Oil works, but it isn't "superior". Rem Oil contains more Mineral Spirits (55%) than Teflon (35%). Mineral Sprits is a degreasing solvent. These two compounds effectively work against each other. Remington put them both into the same can as a matter of convenience to you. They tried to find a balance that does a decent job of degreasing, inhibiting corrosion and lubricating, but the product is superior at neither since the two compounds are applied simultaneously. The best approach is to first use a degreaser and then apply a corrosion inhibitor/lubricant separately.
We're safe to use the WD-40 that we already have on the shelf.
T
Old 04-26-2011, 06:01 PM
Highboy74's Avatar
Highboy74 Highboy74 is offline
Highboy74 is starting off with a positive reputation.
Try this web site.
NORTH COUNTRY SPECIALTIES
Old 04-27-2011, 09:17 AM
daningraham's Avatar
daningraham daningraham is offline
daningraham is starting off with a positive reputation.
I wouldn't wait too long to replace the motor, my squeaky motor caused an overload in the wiring and took out my entire dash. New motor's are cheap and easy to replace.
Cabin fan only on low GuitarJesus 1987 - 1996 F150 & Larger F-Series Trucks 6 10-05-2016 09:00 PM
Engine cooling fan - not a clutch fan? Jonota Modular V10 (6.8l) 5 09-28-2015 02:54 PM
Should fan be spinning constantly 72Truckin 1967 - 1972 F-100 & Larger F-Series Trucks 27 08-28-2015 11:20 AM
95 Explorer Fan Clutch Falcon731 Explorer, Sport Trac, Mountaineer & Aviator 2 05-04-2009 03:54 PM
Fan Clutch issues - always spinning... BigMattXXL 1997-2006 Expedition & Navigator 5 09-03-2003 07:10 AM
Tags
1973, 1979, 2008, 73, 74, changing, f150, f250, fan, ford, frod, heater, motor, pickup, squeak, truck, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
